help quick
Old Jun 10, 2011 | 05:10 PM
icemaidenz's Avatar
icemaidenz
Default help quick
have a chance at a v10 dodge engine can i put it in m 85?if so what other things would i need to convert ie fuel pump etc
Old Jun 10, 2011 | 05:28 PM
JohnTVette's Avatar
JohnTVette
Sounds like opening pandora's box to me.
I'm trying to visualize how that would fit? Doesn't seem like there's enough room to add the length of another cylinder on each side.
Old Jun 10, 2011 | 05:32 PM
pologreen1's Avatar
pologreen1
Are you serious?
First of all don't panic. The viper engines are not that uncommon, unlike the more expensive c4 ZR1 motor.
Secondly it probably can be done if you have all kinds of skills, abilities, imagination, tools, shop, money, friends, etc.
Good luck. It's a pain converting corvette parts to a corvette let alone a viper motor to a vette.
FWIW a clean gen 1 viper can be had for 20K now on the right day.
If you are willing to hack up the c4, then you'd be further ahead to put in a Big Block IMO.
Old Jun 10, 2011 | 05:38 PM
JohnTVette's Avatar
JohnTVette
Originally Posted by pologreen1
Are you serious?
Or just buy a supercharger.
Old Jun 10, 2011 | 05:55 PM
Mohammed_z's Avatar
Mohammed_z
So you want to open the hood of your vette and see a dodge logo there ?
corvette must have corvette engine .
GetLS3, LS7 or LS1 if your budget is tight.
Old Jun 11, 2011 | 11:02 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Build a street rod with lots of room inside the frame rails instead.
Leave the GM all GM.
Old Jun 11, 2011 | 11:22 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
"what other things would i need"
Most likely another 8-10 inches between the firewall and front end.
To help quick
