top removal
Old Jun 12, 2011 | 03:43 PM
craneman61!'s Avatar
craneman61!
Default top removal
What size and type is the bit to remove the top on a 96?
THANKS in advance
Old Jun 12, 2011 | 04:33 PM
thearborbarber's Avatar
thearborbarber
Its a T40 torx bit. Amazon has the ones with a long shank
Old Jun 12, 2011 | 04:52 PM
cuengineer's Avatar
cuengineer
I got a collapsible Torx wrench that contains a bunch of different sizes up to the needed T40 and folds up. I keep it in the console pocket and use it to remove the top bolts. Works pretty well because it has pretty good leverage to tighten the bolts or the initial loosening, but can work almost like a screwdriver to quickly loosen them once they are broken loose. Can loosen all four in about a minute when removing the top. Seems like it is a LOT faster and easier than trying to use a ratchet.
Old Jun 12, 2011 | 06:34 PM
craneman61!
Thanks guys. Appreciate the info.
Old Jun 12, 2011 | 07:28 PM
thearborbarber
This sounds like a nice set up. The ratchet is a neat idea but clumsy in operation.
To top removal
