fuel filter
Old Jun 16, 2011 | 11:31 AM
tc sr's Avatar
tc sr
Default fuel filter
I just changed the fuel filter on my 95 vette and I am getting a vibration on that side of the fuel filter any thoughts when it is in gear it vibrates when I am stoped when I step on the gas pedal it stops any thoughts?
Old Jun 16, 2011 | 11:39 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Make sure you have the mounting bracket mounted properly and securely (that pain in the *** band with the 10mm bolt). Also make sure the other lines are secured. The fuel pump naturally pulsates. If it becomes or is a problem, you may need to replace it. You may also want to check if the fuel pressure regulator is working properly.
Old Jun 16, 2011 | 08:23 PM
enventr's Avatar
enventr
I have a 95 vert. when the filter was changed the "x" brace did cause a vibration. Readjusted the "x" brace and noise went away.You need to fill out your profile so that we know about your car. Is it a vert?
To fuel filter
