89 Wheels....
Old Jun 18, 2011 | 04:21 AM
RicG's Avatar
RicG
Default 89 Wheels....
I have stock 89 wheels ..... Does anyone know how I can get these polished up. These look ok from a distance but up close the surface is crazed and cracked.
Old Jun 18, 2011 | 05:44 AM
jeffp1167's Avatar
jeffp1167
remove tires and valve stems and run them on the car (on jackstands lol) at say 25mph. Sand them with 180/220/320/400wet/600wet then use mothers polish and they will have a real nice shine.
Truck stops generally have polishing services as well and charge about 40-50 a wheel for a chrome like shine
but doing it like I said will take you about a hour a wheel
Old Jun 18, 2011 | 07:26 PM
impact1968's Avatar
impact1968
Send them out to be refinished. When you get them back they will look like brand new. Shops around here charge $125.00 a wheel though. But if you like the 89 wheels like i do it might be worth it to you.
Old Jun 18, 2011 | 07:38 PM
cv67's Avatar
cv67
St. Jude Donor '05
Strip the clear off it then start wetsanding.
They have fine machining marks in them they all need to come out or the polish job will look like butt.
Old Jun 18, 2011 | 08:50 PM
slickfx3's Avatar
slickfx3
the alloy is real hard and sanding will almost do nothing, I stripped mine and it took 3 tries over the years and have spend 15 hours on them, and I still have some clear stuck in some places.
the corrosion runs deep and cannot be sanded off, or bleached out with any chemicals.
this being said, with the clear gone the circular lathe cut surface looks great, not too shiny not too dull. but the corrosion is there to stay.
Old Jun 19, 2011 | 12:24 AM
RicG's Avatar
RicG
Thanks guys for the tips.... Like impact1968 said I do like the wheels so it looks I have some work do here....
Thanks again
Old Jun 19, 2011 | 12:47 AM
cv67's Avatar
cv67
St. Jude Donor '05
Slick, you can get them right.
Did mine by hand in one real long day then went back the next for touch ups. Came out looking professionally done.
Much easier to take them in drop the dough and pay someone.
Wouldnt be in any big hurry to do more though.
Old Jun 19, 2011 | 01:35 AM
slickfx3's Avatar
slickfx3
I forgot you are the undisputed CF "King of Erosion" keep anything resembling aluminum away from you, please step away from the grinding wheel....
seriously, they cleared coated the front surface and painted the recessed areas grey then cleared, it's a mess, but looks good 5 feet away, what can I say I bought them like that...it was way worse.....
To 89 Wheels....
