Head lights
Old Jun 19, 2011 | 03:07 AM
redvetteman81's Avatar
redvetteman81
Default Head lights
My headlights are only opening half way, can anyone diagnose what this could be? And on a 89 vette are the still vacauum like my 81?
Old Jun 19, 2011 | 08:21 AM
HlhnEast's Avatar
HlhnEast
The headlights are not vacuum but gear driven. Both headlights come halfway open and stop? No grinding noises from them?
Old Jun 19, 2011 | 08:55 AM
redvetteman81
No grinding noises, were should i start. What does a repair like this cost?
Old Jun 19, 2011 | 11:17 AM
Wildride's Avatar
Wildride
Cruise-In II Veteran
Most likely the bushings in the drive have gone bad. Happens to ALL 89-96 Vettes! A fairly easy repair-about 45 minutes per unit.
http://www.corvettemagazine.com/body...1988-1996.html
I used bushings from my local Ace Hardware-six for $1.50. Others have used Home Depot (part number used to be 3069987278) or Ford power window mechanism bushings (Advance Auto "HELP" section.
The nominal size I have scribbled down was 27/64 by 29/64. Which is length vs. diameter I don't recall.
Many posts on the subject listed in the "Search" function.
http://forums.corvetteforum.com/sear...rchid=24587396
Old Jul 2, 2011 | 05:15 AM
redvetteman81
I can't beleive to fix the problem was as simple as a little lube.
To Head lights
