1989 instrument panel
Old Jun 24, 2011 | 09:48 PM
ZORA89's Avatar
ZORA89
Cruising
Default 1989 instrument panel
I can not read the speedometer or tach. Is there any way I can repair it?
Don
Old Jun 24, 2011 | 11:02 PM
Sparkytfl's Avatar
Sparkytfl
Well do you mean they dont work, or the lights are just burned out? If it's just the lights, you can change them in half an hour. You need 882 bulbs, four of them. They're eight bucks each.
Old Jun 25, 2011 | 06:36 AM
HlhnEast's Avatar
HlhnEast
Details please.
Old Jun 25, 2011 | 09:57 PM
ZORA89's Avatar
ZORA89
Cruising
A few of the bulbs were burned out so I replaced all of the bulbs. The display is os faint that you can not see the MPH or RPM. Before you could see a little display now I can not see any.
Old Jun 25, 2011 | 10:38 PM
tehcarguy's Avatar
tehcarguy
Do yours look like this?
Attachment 48380533
Old Jun 26, 2011 | 12:59 PM
ZORA89's Avatar
ZORA89
Cruising
Default instrument panel
That looks pretty close to it. The panel lights up with the exception of the MPH and RPM read out. I can just barely make out the digital display of the RPM. That is what I use to judge my speed. I n bright sun light I can not see that. I was told that the panel needs to be sent off to be professionally rebuilt and that it is very expensive.
Don
Old Jun 26, 2011 | 03:32 PM
tehcarguy's Avatar
tehcarguy
If it's got a light spot on it like that when its off, you'll definately need to replace the LCD screens which are around $100 a piece. If you changed the bulbs yourself then you should be able to replace the LCD screens just as easily.
Old Jun 26, 2011 | 08:33 PM
WW7's Avatar
WW7
If it needs rebuilding there are companys that do it for about $150.00..If you need LCD screens thats $100.00 extra for each one...WW
Old Jun 26, 2011 | 10:05 PM
ZORA89's Avatar
ZORA89
Cruising
where is the best place to purchase the LCD screens?
Old Jun 26, 2011 | 10:11 PM
tehcarguy's Avatar
tehcarguy
I bought mine from Jim Adams, he sells these dash parts. You can email him at witchcityeng@yahoo.com.
Old Jun 27, 2011 | 05:58 AM
HlhnEast's Avatar
HlhnEast
You are saying the bulbs are actually lit but you still cant see the display? Is your display complete but dark, i.e. not a partial display like carguy has? If you can see the full display (barely like your talking about) then your LCD's are probly ok and you have lost the ground or the power side of the lighting circuit. The best source of dash info is at
http://www.batee.com/corvette/index.htm
I also just did a write up on the power side here:
http://forums.corvetteforum.com/c4-t...ht-repair.html
Good luck!
Old Jul 21, 2011 | 09:12 PM
betcorvette's Avatar
betcorvette
Looks to me like a polar film problem. Look at the dash with a good pair of polarized sunglasses on, and, if this is the problem, you will be able to see all the numbers. I've found the film for @$15. I'm researching whether I have to pull the entire dash out, or can just apply the film from the outside. It comes with or without adhesive. I hope this is your problem because it is a lot cheaper to fix that anything else. Good luck, and please let me know if this is the fix?
Old Jul 21, 2011 | 10:47 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Damn, you're a busy little poster. 3 threads on the same subject.
Have you even pulled the bezel and looked to see if the bulbs are burnt out yet?
Do you know how to pull the bezel?
Did you look at the Batee website?
Old Jul 23, 2011 | 10:29 PM
betcorvette
Yes, I have been busy trying to find out if I can fix it myself, so maybe "desperate" is a better word. lol All the bulbs are working fine. I went to Batee, but that was for a total take down/apart which I am trying to avoid. Also, like I said, I know it is the polarized film problem and he dosen't cover that at his site. I'm sure I can pull the bezel, but I don't see how that will get me any closer. The adhesive film can just stick on the front, I think, thats why they advertise both for the Corvette Dash fix. One site even has different colors, but I'll stick to the amber. Thanks for the quick answer, but I know it's not the bulbs
To 1989 instrument panel
