Cruise Control Not Working
Old Jun 26, 2011 | 02:14 AM
Atlanna's Avatar
Atlanna
4th Gear
Default Cruise Control Not Working
Hey Guys, still new to the forum and could use some help. My 95 C4 is finally starting to show her age, had to replace the transmission last month and the brake booster a couple of wks ago, I normally only drive 3-5 miles a day so no need for the crusie until I took a long drive, anyway after a 100 miles I noticed my cruise doesn't work and to far now to return to the dealer. Would appreciate any help/ideas. Thanks
Old Jun 26, 2011 | 08:40 AM
Analog Kid's Avatar
Analog Kid
Check the 2 vacuum lines coming and going to the cruise control servo. The servo is the diaphragm device just above the battery. It's possible that while your brake booster was being replaced, a vacuum line was knocked off or torn.
Old Jun 26, 2011 | 01:17 PM
Atlanna's Avatar
Atlanna
4th Gear
Thanks! My wonderful brother-in-law is going to take a look at it for me.
Old Jun 26, 2011 | 01:45 PM
Frizlefrak's Avatar
Frizlefrak
Check...
Voltage from switch to servo.
Vacuum lines and servo diaphragm (test with vac pump)
Brake and Clutch switches.
Old Jun 27, 2011 | 12:16 AM
Goldcylon's Avatar
Goldcylon
Also check under the brake pedal. If the brake switch is offset of the pedal arm the Cruise Control will not set. It must be centered on the pedal arm. GC
To Cruise Control Not Working
