AC Fan Problem
Old Jun 26, 2011 | 01:04 PM
revival1's Avatar
revival1
Default AC Fan Problem
How hard is to change the fan for the AC under the dash? When I 1st put it on it squeaks on high. If I turn it on and off a few times it’s OK.
Thanks in Advance.
Old Jun 26, 2011 | 01:08 PM
revival1's Avatar
revival1
Should I be saying blower motor?
Old Jun 26, 2011 | 04:35 PM
jfb's Avatar
jfb
It is easy, the motor is bolted to a plate that is bolted to the blower housing. When you remove the plate with the motor attached, I'd squirt some oil onto the motor shaft behind the squirrel cage blower wheel, that might stop the squeeling.
To AC Fan Problem
