92 vette a/c problem
Old Jul 1, 2011 | 04:09 PM
monkeycit's Avatar
monkeycit
Cruising
Default 92 vette a/c problem
hey amigos, compressor on my vette is not coming on. freon ok. take relay off and jump wires from E to A and compressor runs. have replaced relay and still the same. wont run on its own. have voltage on coil and from E to A on relay. lost here. what am I missing.
Old Jul 1, 2011 | 04:17 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
is the inside controller ant good
Old Jul 1, 2011 | 04:22 PM
monkeycit's Avatar
monkeycit
Cruising
thanks nowhere man. did take controller out from dash and opened. circuit board inside. all buttons function and light up. turn blower on and off. how can I check if controller is bad?
Old Jul 1, 2011 | 04:43 PM
Nowhere Man
do you have the manual heater control or the optional electronic. also the service manual could be very handy to help you
Old Jul 1, 2011 | 04:49 PM
monkeycit's Avatar
monkeycit
Cruising
not sure. it has a circuit board inside. however must turn on manually from off to a/c or heater.
Old Jul 1, 2011 | 04:54 PM
Nowhere Man
does it have a slider bar or all buttons along a screen that tells you the outside temp and inside temp
Old Jul 1, 2011 | 04:56 PM
monkeycit's Avatar
monkeycit
Cruising
Old Jul 1, 2011 | 05:00 PM
Nowhere Man
there are steps somewhere on how to get codes off that screen to help diagnose problems with the HAVC
Old Jul 1, 2011 | 07:34 PM
QZRBLU's Avatar
QZRBLU
2017 C4 of Year Finalist
monkey,
This should get you going it the right direction......
http://www.corvetteactioncenter.com/...agnostic+Codes
Old Jul 1, 2011 | 07:44 PM
monkeycit's Avatar
monkeycit
Cruising
Originally Posted by QZRBLU
monkey,
great. thanks ozrblu.
Old Jul 2, 2011 | 08:47 AM
monkeycit's Avatar
monkeycit
Cruising
Thanks for ur help too nowhere man.
Old Jul 2, 2011 | 10:41 AM
pitchadude's Avatar
pitchadude
Just put rebuilt ac compressor on mine. My clutch was dead. Found compressor with clutch on E--Y for a great price.
Old Jul 2, 2011 | 01:33 PM
monkeycit's Avatar
monkeycit
Cruising
Thanks. I'll check that out too.
Old Jul 2, 2011 | 11:14 PM
monkeycit's Avatar
monkeycit
Cruising
Clutch on compressor running good. What is the ohm's I should get on the relay coil? I removed the relay off its shell and closed the relay points with a piece of small paper. Since I do have volts on the relay coil, jumping the E and A points makes the A/c run, cooling good. The problem is E and A wont close by itself. Any ideas?
Old Jul 2, 2011 | 11:34 PM
QZRBLU's Avatar
QZRBLU
What error code did you get from the test instructions above? amigo?
Old Jul 3, 2011 | 12:01 AM
monkeycit's Avatar
monkeycit
Cruising
did not get any that I could make out. Went thru each one on the checklist and just gave me the parameters listed.
To 92 vette a/c problem
