here is what happend a few days ago my freind was changing my 02 sensor up front on the manifold connected to the exhaust when the clip broke that connects the wire from the car to the sensor, i drove the car today and after 10 minutes at a drive thru my car was acting like it wanted to shut off and my radio is losing power and my lights on dash were going out, how can i get this switch fixed and is this systoms of the 02 sensor not connected properly.
Car was acting like it wanted to shut off , my radio is losing power and my lights on dash were going out,
Sounds more like a power problem like batt going flat or bad connections somewhere.
What was your Voltmeter reading when you had problems?
If batt voltage goes too low, the computer will shut down.
No
If the computer doesn't see the O2 sensor ,engine will appear to run fine ; except your fuel economy will be cr*p.
