Head light problem
Old Jul 23, 2011 | 04:51 PM
Maxo's Avatar
Maxo
Default Head light problem
On my C4 the left head light makes a clicking noise when it reaches he top, coming from the motor. I stops clicking after about 8-10 clicks. And the clicks repeat when It door goes to the close position. The right light does not open. That might be a bad motor. Can anyone give me some tips on the clicking and how to check the right motor.
Max
Old Jul 23, 2011 | 06:23 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Not sure what year your car is but my 93 did pretty much the same thing and I replaced the three bushings in both sides and that solved the problem. The headlight thats not going up could be the motor but you should be able to tell if the motor is running or not. If it is and not flipping up then it could be the gears or the bushings. On my car there was a pile of white dust under each headlight and that was the old bushings disintegrating into powder. Pulling the headlight buckets out for a fix isn't a big job but it does take a little time the first time you do it.
Old Jul 23, 2011 | 07:00 PM
joe paco's Avatar
joe paco
Max
there's a sticky above, also some videos of how to do it. bushings, that is. also, some have bought them at Home Depot, don't have the part number handy but have it.
joe
Old Jul 23, 2011 | 09:54 PM
Maxo's Avatar
Maxo
Hi
Thank you for your help. My car is a 1991. It had been hit in the front and the entire front end was replace. Since then the left light has always clicked. sometimes it even get hung up. I will open up the buckets and examine the gears. Thank you. Are the bushings where did you get the bushings to do your repair????
Old Jul 23, 2011 | 09:59 PM
Maxo's Avatar
Maxo
Hi Joe,
Thank you for taking the time. I am intrested in watching the video and reading the sticky, however I dont see either. Can you direct me there ?
_____________
Maxo
Old Jul 23, 2011 | 11:04 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Here is the sticky. https://www.corvetteforum.com/techti....php?TopicID=2 Sorry I didn't have time to look for the video.
Here is the pictorial:http://www.corvettefever.com/howto/33098/index.html
Old Jul 24, 2011 | 08:48 AM
Maxo's Avatar
Maxo
Joe,
Thanks again this is very helpful.
_________
Maxo
Old Jul 24, 2011 | 09:08 AM
joe paco's Avatar
joe paco
Joe,
_________
Maxo
http://home.comcast.net/~zrjuan/headlight.html
that was not joe, another member, junior!
got mine from echler's. these are plastic pcs that have $.02 of plastic but are correct dimensions.
# 3069987278 is a partial HD number. might have a couple zeros in front. also advance auto has them under "ford pwr window bushings." apparently just a common bushing in car industry.
joe
read all the posts that are sent, someone has the info.
Old Jul 24, 2011 | 09:51 AM
richauto's Avatar
richauto
Max
As far as the right motor goes, always check for power and ground before replacing parts. Could be a bad connection. good luck
Old Jul 24, 2011 | 04:07 PM
Maxo's Avatar
Maxo
Thank you for the tip !
_________
Maxo
Old Jul 24, 2011 | 11:03 PM
Movnviolation's Avatar
Movnviolation
Just eplaced plastic gears and bushing on my 89. I removed the whole light unit on both sides. first one took about four hrs, second one took 40 minutes, piece of cake, got everything from ecklers.
Old Aug 29, 2011 | 09:43 PM
Maxo's Avatar
Maxo
1991 Rightside head light motor does not seem to work. Nothing happens when I turn the lights on.
_____________maxo
Old Jan 3, 2012 | 07:15 PM
Maxo's Avatar
Maxo
Hi Joe,
This is Maxo, once again you gave me a thread from a guy who posted the pictures of how to replace the headlight bushings. I was wondering if you could be so kind to take the time once more to resend it to me. I checked on the sticky you forwarded but the head light replacement is not there or I dont seem to find it. It's winter and I plan to tear into the headlights and replace the bushings and or gears. Your help is appreciated.
Maxo
Old Jan 3, 2012 | 07:32 PM
shamdave's Avatar
shamdave
or you can do the Fiat headlight conversion
Old Jan 3, 2012 | 07:39 PM
Maxo's Avatar
Maxo
Thanks for the tip and the pic. I prefer the stock look. Just curious is that a kit.
Maxo
Old Jan 3, 2012 | 08:21 PM
Maxo's Avatar
Maxo
Default How do I post a pic of my car next to my name
and What does it mean Whats in my garage?
Old Jan 3, 2012 | 08:42 PM
oldalaskaman's Avatar
oldalaskaman
actually read the thread, sorry
To Head light problem
Old Jan 3, 2012 | 08:43 PM
mrmtrtrnd's Avatar
mrmtrtrnd
You can go into your profile and add pictures in there in the area called Garage.
Old Jan 4, 2012 | 04:55 PM
shamdave's Avatar
shamdave
Maxo
Nope not a kit , a crap load of cutting and sanding The head lights are a fiat 20vt
Old Jan 4, 2012 | 09:12 PM
Maxo's Avatar
Maxo
Yeah, that;s Ok but all plastic turns yellow with time. Thanks for the infomation.
