Long Tubes
Old Apr 26, 2002 | 11:22 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
Default Long Tubes
Who makes a good long tube header for the LT1 (1995)?
Coated, with all emission hook-ups. Approx.$price$
Old Apr 26, 2002 | 11:30 PM
365ZUM's Avatar
365ZUM
Cruise-In III Veteran
Default Re: Long Tubes (Vette Ed)
1. Exotic Muscle http://www.exoticmuscle.com $650 shipped
(Prevents use of Canton racing oil pan)
2. TPIS http://www.tpis.com $700+shipping
3. Hooker 2149's http://www.speeddemonmotorsports.com $5-- (less without ceramic coating)
Hope this helps. :cheers:
Old Apr 26, 2002 | 11:32 PM
Vette Ed's Avatar
Vette Ed
Thanx Ross!!!
Old Apr 27, 2002 | 11:43 AM
365ZUM's Avatar
365ZUM
No prob! :chevy
Old Apr 27, 2002 | 01:50 PM
Bill Reid's Avatar
Bill Reid
Default Re: Long Tubes (365ZUM)
2149's are used on LT1's :confused: Hooker shows 2061 for uncoated and 2061-1 for coated although I'm not sure if they are long tube or shorties designed to work with your existing cats. Not saying it can't be done... just that Hooker has part numbers specific to 92-95 LT1's :)
http://www.holley.com/HiOctn/ProdLin....html#Corvette
... and Hookers are ALOT cheaper... with excellant quality... here's my 2149's. Take a look at the air tubes and see if its a direct bolt up for you at the head flanges. Running 2149's, if possible, will require you to relocate your cat(s). Planning on dual exhaust?
[Modified by billreid1@***.net, 11:59 AM 4/27/2002]
[Modified by billreid1@***.net, 12:00 PM 4/27/2002]
Old Apr 27, 2002 | 02:34 PM
365ZUM's Avatar
365ZUM
Default Re: Long Tubes (billreid1@***.net)
The Hooker 2061's your reffering to are the shorty headers. They're basically a waste of money IMO- No HP/TQ increase to speak of, more difficult access to plugs, and most of them cost two thirds (if not the same) price as long tubes. But, they WILL fit with your existing cats, so it's considered a "bolt-on" that's the reason the Hooker specifies the 2061 for LT engines.
I can't speak from first hand experience, but from what people say- the Hooker 2149's are an excellent fit on LT's. MANY forum members have them. As with the addition of ANY long tube header on an LT engine, you will need to buy some aftermarket cats
- Random Tech [expensive] http://www.randomtechnology.com
- Carsound [average] http://www.car-sound.com
- Catco (Dynomax) [cheap] Summit, Ecklers carry them
LT engines have true dual exhaust systems anyway! SO, make sure you buy two. I have personally seen dyno's of people gaining nearly 35hp from going to long tubes alone. I'm sure several people with LT headers will chime in. Good luck. :cheers:
Old Apr 27, 2002 | 04:38 PM
ZBRA's Avatar
ZBRA
I will be ordering a set next month for my '94. I am yet undicided if I am going with the EM or TPIS. I am leaning toward the TPIS. I plan to do away with the cats and AIR stuff while I am at it.
Any pros or cons between these two.
Old Apr 27, 2002 | 04:53 PM
365ZUM's Avatar
365ZUM
Default Re: Long Tubes (ZBRA)
[QUOTE
Any pros or cons between these two.[/QUOTE]
I had EM headers. However, I have found that they do NOT fit with a Canton racing oil pan. MORE Perf. is in the process of rebuilding my LT4 due to oil starvation, so I've learned my lesson: Canton oil pan it is! SO, I'll soon be in the market for another set of headers. From the homework I've done, TPIS is the second best. Several forum members run them without any complaints. They are also said to be an easy fit.
If you don't plan on adding a racing oil pan- go with with Exotic Muscle headers. The reason they don't fit with one is that they are made to tuck tightly into the undercarriage of the vehicle- a good thing (prevents clearance issues commonly associated with others). Cheaper too. EM does sell a "nameless" oil pan that they swear fits with their headers, but its much more expensive.
SO- Canton oil pan= TPIS headers
Factory oil pan= Exotic Muscle (takes a LONG time to get them shipped to you though)
:cheers:
[Modified by 365ZUM, 3:56 PM 4/27/2002]
Old Apr 27, 2002 | 05:53 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
Get Stainless steel if you can........ceramic starts to look like **** after a while(Rust,etc...). :yesnod: :(
To Long Tubes
