Key fon
Old Jul 27, 2011 | 12:41 AM
swiftvetc4's Avatar
swiftvetc4
Default Key fon
My 94 key fob is nuts, reprogramed and replaced battery, works for a while but really only with PKE system then seems to go dead, i looked at manual seems to be 100s of possible reasons, is replacing the fob a good starting point?
Old Jul 27, 2011 | 07:46 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
More details please.
What do you mean "but really only with PKE system"?
Old Jul 27, 2011 | 10:34 AM
markKlein's Avatar
markKlein
"but really only with PKE system "
this statement makes me think you do not understand how the system works. The C4 factory fob only works as a PKE system. There is no push buttons to lock/unlock capability. Look at the fob; there is a button to open the hatch (if you have a coupe fob), there is a button with a picture of a door, this sometimes unlocks the passenger door, and also turns the system on and off. There are no buttons labeled LOCK and UNLOCK. (This is all spelled out in the owners manual).
Sounds like the fob works fine. Because of the way the system works, the fob is constantly transmitting whenever it is moving. Some people wear out the fob battery in a few months, for others they can last years.
Old Jul 27, 2011 | 10:59 AM
swiftvetc4's Avatar
swiftvetc4
Ok I get that part, it stops working the PKE all together after a few try's, when you hold the door button down for 2 seconds to turn off the PKE and then reverse to turn back on the system won't work, also takes a few attempts to reprogram the key fob, the 2 nd key fob won't program thanks
Old Jul 27, 2011 | 11:11 AM
George6488's Avatar
George6488
Both key fobs have to be programmed at the same time....not separately.
If you program them separately....only the last one programmed works.
Start the programming cycle with both fobs more than 20' from the car and then go get one at a time to program. Take the first away after programming and then bring the second to the car for programming. In this manner....they both will work for you.
Old Jul 27, 2011 | 11:40 AM
swiftvetc4's Avatar
swiftvetc4
Yes did it like that, I think the 2nd fob is bad and 1 st one is on the way out , considered buying new ones, cc vet is 150 MA vet is 180
Old Jul 27, 2011 | 11:32 PM
CE1's Avatar
CE1
gmpartsdirect.com $ 103
To Key fon
