TPS/Rough idle Help
Old Jul 29, 2011 | 02:16 AM
Cousar33's Avatar
Cousar33
Default TPS/Rough idle Help
My 86 Corvette has recently been having trouble idling when starting. Sometimes in the morning it will start then stall slowly. Then after i have to give it gas and warm it up to get it going. I have an obd1 code 22 for tps but idk what it could be. Also i think im missing a wire or it isnt connected on my tps(no wire running). Also where does it connet to? Please help
Old Jul 29, 2011 | 05:27 AM
HlhnEast's Avatar
HlhnEast
Why do you think you have a wire missing? IIRC the TPS has 3 wires. You use the top two to set it. Its pretty easy but you have to have a digital volt meter.
My FSM says your Code 22 is TPS voltage is low. Check that out and get back to us.
Old Jul 29, 2011 | 11:39 AM
Cousar33's Avatar
Cousar33
I messed with it and found it had a loose connection. The light went away after reconnecting it. The car still stalls out and if it doest the rpms go up and down from 5 to 12 until they hit 0 and stall. I think it might be the iac
Old Jul 30, 2011 | 12:28 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
You should set the base idle, then the TPS idle voltage and clean out the IAC.
Old Jul 30, 2011 | 12:44 AM
vader86's Avatar
vader86
Theres a procedure on my page to setup the TPS and IAC. Its very likely one or both behind it.
http://temp.corvetteforum.net/c4/vader86/tpsiac.html
First, clear the codes, see if this continues. If the 22 comes back, follow the procedure to determine if the sensor is bad or its wiring.
http://members.shaw.ca/corvette86/Code%2022.pdf
Then go on to checking things out in the link above.
To TPS/Rough idle Help
