Just wondering
Old Aug 2, 2011 | 06:15 PM
JIMBO7's Avatar
JIMBO7
Default Just wondering
So my fuel system is 'pressurized' as it all releases when gas cap is removed.
So how does water get into the tank during a heavy rain if the drain in the tank fill rubber surround (boot) is plugged with leaves or whatever? I mean it's 'pressurized' right?
Old Aug 2, 2011 | 06:21 PM
F22's Avatar
F22
Condensation is how water gets in the tank.
Old Aug 2, 2011 | 06:24 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
The "pressurized" part of the system is from the fuel pump to the injectors.
Not so much the fuel tank, although there can be some pressure build up.
But that is from the normal heating/cooling cycle of the surrounding atmosphere.
You can prove this, by taking the fuel cap off and noticing the engine will still run.
Although (at least on later models), it will cause the "Check Engine" light to come on if left off or loose for any length of time.
Old Aug 2, 2011 | 06:31 PM
Sweet 90's Avatar
Sweet 90
Bad gas cap.
Old Aug 2, 2011 | 07:21 PM
JIMBO7's Avatar
JIMBO7
So the cap lets water in even though it keeps the air pressure in?
Old Aug 2, 2011 | 07:37 PM
inedajob's Avatar
inedajob
I think you hear suction when removing the gas cap, not pressure release.
Old Aug 2, 2011 | 08:27 PM
Sweet 90's Avatar
Sweet 90
If you have a bad gas cap, it will not let any pressure build up, allowing water to enter, especially if your drain is plugged.
To Just wondering
