power window switch
Old Aug 2, 2011 | 07:11 PM
loucazo's Avatar
loucazo
Default power window switch
Does anyone know where i can get a drivers side window switch for a 1994 corvette. I from canada and i called the dealership but they say parts are dicontinued and no longer shipped to canada.
Old Aug 2, 2011 | 09:03 PM
3D87C4's Avatar
3D87C4
Bummer...Ecklers and Corvette Central both have the right side switch but not the left side (shown as discontinued on the Corvette Central web site).
I just replaced my power door switch in my '87, which is also used for the windows, & thought I'd be so helpfull mentioning that. Now I see it's just salt in the wound, sorry.
Put a want to buy add over in the parts section and/or check with some of the dismantlers in the vendor directory is the best I can offer.
Good luck
Old Aug 2, 2011 | 10:18 PM
Calderone's Avatar
Calderone
http://www.mamotorworks.com/corvette.html?frame=3.1079 ???
Old Aug 2, 2011 | 10:40 PM
daddysvet92's Avatar
daddysvet92
Where in Canada?
I have bought new ones from Tracy Performance Vette in Roseville, Michigan. Info: 586-772-8893 , Fax: 888-FX-TRACY , Order Line Only: 800-UC-TRACY
I live on the border of Detroit, Michigan and Windsor, Ontario.
When I need things, I go over and buy them, and show the parts I bought to Customs on the way back into Canada.
Fairly easy doing it this way!
If you need more info, you can send me an email to:
daddysvet92@gmail.com
Chris
Old Aug 2, 2011 | 11:21 PM
loucazo's Avatar
loucazo
Originally Posted by Calderone
This site was helpfull.... but for my year it says no longer available..
Old Aug 3, 2011 | 01:02 PM
whitenow's Avatar
whitenow
Default Is it just not connecting?
The contacts can be cleaned, restoring the switch to functional. I could send you a loaner for you to use while I clean yours, or just swap with you paying shipping both ways.
Old Aug 3, 2011 | 01:53 PM
Biker's Avatar
Biker
Don't bother with MidAmerica. Their window switches are poorly made. Mine became wobbly in the switch housing with intermittent contacts in about 6 months. Do yourself a favor and buy genuine GM parts. That's what I did the second time around.
Old Aug 3, 2011 | 02:42 PM
C4GUY's Avatar
C4GUY
It probably just needs to be cleaned. Start there. I recently bought a 1995 low mileage car, passenger side switch only worked in down. I was able to get it working simply by flicking it up and down a bunch of times, leading me to beleive it is just corroded and when I stop being so lazy I will take it out and clean it correctly.
To power window switch
