I hope that some of you "interpret smoke" After sitting for a couple of days, my car lets out a puff of dark smoke upon starting. It is not blue, which I think oil would be so........
I drove to the corner drug store to pick up a prescription for my wife; when I got out of the store from that, there was no smoke.
It only happens after it sits for some period of time apparently. The car starts immediately.
The car has 53,000 miles on it; the mechanics took out the spark plugs and told me that it "looked good", whatever that means.
I really appreciate your input--all of you-- I would imagine the injectors need attendtion in any case and this seems the least expensive first fix; am I right?
The valve stem leak would necessitate taking off the heads, I guess. This sounds like major surgery that I could not do my self.
I am going to "research" getting the injectors rebuilt as one of you suggested. First where are they located ? The last tune-up I did was in 1959 on my 1951 Chevrolet hardtop.....was my last disaster.
Kistler
If they are stock, I would say it is time to have them tested and cleaned if necessary.
That is one way to do it. Since it doesn't have overhead cams, it probably isn't the end of the world to do that. In any case, it can be done WITHOUT head removal.
Absolutely true. However, sometimes it is hard to see between blue and black if you are sitting in the car. Besides, I do question why it happens after it sits for a while and not all the time
It is a stock 5.7L...only thing different is the former owner added an Alpine radio/CD and something I don't understand AND originally it was ordered/has sports seats.
Aaah, "the return line"....the people I took it to for the initial (should I buy it or not mechanical inspection) inspection said that a fuel vapor return line was leaking.... I think they also said (not written out) that there was gas in a cannister???????
????because the local garage I took it to could not find this to be the case. Maybe the local garage has missed something. The did $589 worth of flushes and filter changes.
Kistler
I wouldn't worry about that. Some of us have even deleted that (Vapor recovery canister). If the line to the canister is full of vapor, it might be that the intake manifold vacuum is sucking the extra fuel in and causing that issue. If I understand it correctly, it is to trap fuel vapor for emission purposes and allowing it to be burnt in the combustion chambers. HOWEVER, if that line were leaking, how would it suck the vapors into the canister and let the engine suck it up for combustion?
Not sure what they flushed. I would do a rear end flush, trans flush, power steering flush and new filters but not much more than that. I usually change all the fluids when I get a new vehicle.
OK, will not worry The local people did those flushes -- changes of coolant, engine oil, PS oil, brake fluid, fuel filter; I don't think they did the posi traction/differential though.
My wife is in recovery from surgery so if "she were to fall into the drivers seat" to start the money pit she might not every recover -- when my neighbor (he was a Chevy dealer in Nebraska) gets home I will have him do the sniff/sight test. The only problem there being is that he smokes (cigarettes) and may have lost his sense of smell--he can still see.
Kistler
I'd do the posi but those are all good things that were flushed.
I wouldn't worry about that. Still, you should have your injectors cleaned and tested so if it comes back and still does that, you might have other issues like the valve stem seals.
If the L98 has the aluminum heads I would say it was the valve stem seals. It's common for it to smoke on start up after the oil has settled through the valves. Fuel would burn everytime you'd start it.
Thanks Muffin for the info, details. By the way, when describing my Corvette is it enough to say it is "stock" 5.7L? As far as I know it is/was ordered for fun and not the drag strip. I don't think it is an LT1; am I right?
