hardtop squeaks
Old Aug 7, 2011 | 09:51 AM
starfire54's Avatar
starfire54
Default hardtop squeaks
I have a 1996 convertible/hardtop and the squeaks are loud, I wanted to know if this life with the hardtop or can this be corrected?
Old Aug 7, 2011 | 09:55 AM
navy_vette's Avatar
navy_vette
Your weatherstripping has probably become flat and is not longer holding the top solid. I had the same problem with my Targa top before. Replace weather stripping. I just saw a post about Wilcox having a sale.
Old Aug 7, 2011 | 10:03 AM
c4cruiser's Avatar
c4cruiser
Weatherstripping does get hard and will flatten some. Have you tried putting a very light coat of dielectric grease on the weatherstripping? That helps to keep the rubber soft and prevents a lot of the drying out.
Another possibility is not installing the top correctly or not tightening the bolts. Do you have the factory install instructions??
Old Aug 7, 2011 | 10:21 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
try tightening the rear bolts first, then the front
Old Aug 7, 2011 | 10:31 AM
starfire54's Avatar
starfire54
I have the owners manual directions!
Old Aug 7, 2011 | 10:35 AM
starfire54's Avatar
starfire54
The car was garaged, but I think the weather strip is probably old, the seals on the rest of the car are in good shape, so I did not suspect the hardtop area. I will look into removing the top and inspecting the weather strip.
Thanks as usual!!
Old Aug 7, 2011 | 10:37 AM
starfire54's Avatar
starfire54
What is the full name for Wilcox? I did a google search on Wilcox and had no luck finding them?
Old Aug 7, 2011 | 10:39 AM
starfire54's Avatar
starfire54
Never mind I should have looked on the forum. My bad!
Old Aug 7, 2011 | 11:03 AM
navy_vette's Avatar
navy_vette
It's all good. If you do the weatherstripping, do ALL OF IT at the same time. It'll come out a lot better.
Old Aug 7, 2011 | 11:17 AM
GreyGhost's Avatar
GreyGhost
When I put my hardtop on in the fall, I
drive it for a week and then tighten all
the bolts again, it is amazing how much
more you can turn them. Try that also.
To hardtop squeaks
