Convertible jack points?
Old Aug 10, 2011 | 03:29 PM
Jayhawk62's Avatar
Jayhawk62
Default Convertible jack points?
My book (1987 owner's manual) states to place the jack on the jack point--is this marked by the triangles molded into the flange?
Do I place the jack under the flange? Will the flange support the weight?????
When I got new tires recently, Discount Tires was very careful--jacked the car with four floor jacks and had the doors open and the hood up. Apparently they had cracked a Corvette at some time. I think it was a coupe.
Kistler
1987 convertible
Old Aug 10, 2011 | 04:13 PM
pmihaltian's Avatar
pmihaltian
Slingshot
See attached.
File Type: pdf
Old Aug 10, 2011 | 04:36 PM
Jayhawk62's Avatar
Jayhawk62
Thank you, Sir! I printed the pages and will store them in the console for when I am towed or get a tire changed......I am sure it's going to happen
Kistler
Old Aug 10, 2011 | 05:54 PM
Klondike's Avatar
Klondike
I wish tire places would get over the "remove the roof and open everything" hangup. The C4 is a lot stiffer with the top bolted down. I can jack up one corner of the car and lift the whole front or rear and still open & shut all the doors. The tire shops are stuck in the 60's with those "stiff as a tortilla" C2's & C3's!
Old Aug 10, 2011 | 06:09 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Some myths will never die, and I am afraid this is one of them.
To Convertible jack points?
