steering question??
Old Aug 11, 2011 | 09:22 AM
ETRBUJ1984's Avatar
ETRBUJ1984
Default steering question??
I have recently notice a nice kink or binding biulding up in my wheel more so at a certain point in my turn is there any spicific loob point i should hit or any specific thing i should look for?
Old Aug 11, 2011 | 09:27 AM
Goldcylon's Avatar
Goldcylon
A new rack replacement maybe necessary. Get the front end up in the air and have somebody turn the wheel while you look for binding with a flashlight.
Old Aug 11, 2011 | 02:06 PM
ETRBUJ1984's Avatar
ETRBUJ1984
Thanks ill try this out!! Is there any possibility that it might be in the steering column... Or would something like this just be in the rack and pinion?
Old Aug 11, 2011 | 04:36 PM
Goldcylon's Avatar
Goldcylon
I would suspect the rack before the steering wheel. Reguardless the cost to get her up in the air is free beside your time. Use jackstands for safety
Old Aug 23, 2011 | 08:36 AM
ETRBUJ1984's Avatar
ETRBUJ1984
Default been a while but i got it up on the stands
so its been a while sence i had a day off but i got it up on the stands and it make a sound like the ocean no binding when its up there seems pretty free but like i said maybe just air in the line? What can i do cracck one line and try to bleed it or? im not too firmilar with a rack and pinion so any help would do thanks
Old Aug 23, 2011 | 09:00 AM
Muffin's Avatar
Muffin
Rack and pinion is self bleeding. I would consider some professional help. If the binding goes away when the load is removed, that is off the ground, my first guess would be something not right in the suspension.
Old Aug 24, 2011 | 04:48 PM
ETRBUJ1984's Avatar
ETRBUJ1984
and does it sound like a seal kit maybe is worn when u can hear swishing of fluids back and forth when u crank the wheel? Its just about the spot where i feel that it binds on the ground its strange i hope i dont have to take it to the stealership or mechanic!!
To steering question??
