Bouncing knock in rear
. But wait, there is more to this story.... Anyways one day I decided to adjust hight on car abit. I turned the spring nut, actually not much just trying to evenout the car, maybe off by about 1/4 inch. Then knocking comes back. All I did is turn that spring nut and knocking came back, how can this be?????Well I thought bushings but I put new bushings in there not long ago.
Could it be the spring?,, I did noticed that bushings were different from old wornout ones. These are Energy Susp Poly Bushings, and the stock were rubber and sort of had a curved fit into upper cup, and new ones just had a small lip. Could it be that adjusting screw could be knocking on sides of spring or retainer cup? Only other thing I have not checked is that I heard that outer control arm joint needs greasing, but the knock is only over bumps, even small pot holes etc...
Look the upper and lower bolts. I just experience this issue when I drove on Mattole Rd. Betty Boop's driver side lower shock nut was loose and it was making that noise everytime it bumped.
