I've got an 88' with standard seats. I got new foam/recovered vinyl and I'm not happy with them at all. Too hot and the foam is really uncomfortable. ContemporaryCorvette has seats pairs for $350 and up used, thinking about picking up a set.
I'm considering getting some 89-90 standard seats
1. Are all Vette seats interchangeable? I'd assume they would fit, but I'd like to make sure I won't have a problem bolting up the 89-90 seats. I like the 89-90 seat a lot better as far as aesthetics and they look like they have slightly better bolsters.
2. Does the drivers seat come in manual? I'm not a big fan of power seats, but I'm not sure if I can get the seats I want in a manual bracket.
3. If I have to get a power drivers seat, is the electrical connection the same, meaning will all the power adjustments work with my stock wiring harness/connectors?
C$4 seats will all fit, other years will with a bit of adapting, you can use manual or power seat tracks, only difference thru the c4 years is weather its a round or flat pin plug with the power, and you can change those
