1987 dash lights?
Old Aug 13, 2011 | 07:33 PM
Jayhawk62's Avatar
Jayhawk62
Default 1987 dash lights?
Is it true that there are bulbs that can be replaced? Having time left (probably at least 10) I was wondering if any of you have taken the dash board apart and put in new bulbs.
For 1,000 $ or such I think I can take my time and many labeled plastic cups for screws to take the thing apart.
Should I give up and just send it in to .... I forget...some catalogue people...same ones that say send your seats in
Kistler
Old Aug 13, 2011 | 07:44 PM
oldalaskaman's Avatar
oldalaskaman
napa sells the bulbs, you can change them from the front.
Old Aug 13, 2011 | 07:51 PM
Jayhawk62's Avatar
Jayhawk62
Hi Sir: Could you send directions? I can dimly see oil pressure and I do not really feel it's pressing but I would like to return this "old girl" as much as possible to her original glory.
Kistler
Old Aug 13, 2011 | 08:26 PM
oldalaskaman
remove dash bezel, you'll see some shiny alliminum covers ,'round' , gently remove them, use needle nose pliars to remove the bulbs.
Old Aug 13, 2011 | 09:58 PM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
Once you take the plastic bezel off, you can see the round metal covers.
It takes 4 bulbs # 882. (Expensive lil' suckers, too)
Old Aug 13, 2011 | 10:13 PM
oldalaskaman
doing it from the front ,you only need the bulbs, dont let them sell you the sockets also
Old Aug 13, 2011 | 11:52 PM
jfb's Avatar
jfb
Wrap masking tape around the bulbs and use the needle nose pliers on the tape overlap and pull STRAIGHT out. Do not rotate the bulbs because they plug into a twist lock socket that is behind the circuit board and if you rotate those sockets, they fall down and you then must remove the whole cluster and take it apart to reinstall the sockets. Use some tubing to hold the new lamps to insert them into their sockets and use a screwdriver through the tubing to hold the bulbs in their socket while you remove the tubing.
Old Aug 14, 2011 | 05:55 AM
HlhnEast's Avatar
HlhnEast
I used tape covered surgical hemostats to reach in and grab the bulbs. If you can find a set of these they are extremely useful for reaching into tight spots, soldering wires and as a heat sink and holding the occasional roach........not really!!! Maybe 30 years ago.
Oh yeah, do not handle the bulbs with your fingers. The oil in your fingers will lessen the life span of the bulbs.
To 1987 dash lights?
