’90 dash light?
Old Aug 13, 2011 | 10:05 PM
ßill's Avatar
ßill
Default ’90 dash light?
After tinting the windows on my ’90 coupe I had trouble seeing my speedo during the day. I’m thinking that the ambient light inside the car had been reduced causing the dash back lighting to be reduced. Has anyone else experienced this? What did you do?
Old Aug 14, 2011 | 10:48 AM
Churchkey's Avatar
Churchkey
Do not have tinted glass on my 90 however my display was difficult to read, probably sun faded.
I installed polarization film on the display & it brought it back to life.
http://www.polarization.com/polarshop/
If you would like to try the film I have enough left over material to do another car. PM your mailing addy & I'll send it NC.
While the cluster was out I cleaned all the bulbs & removed the aggravating 1-4 shift bulb, the change oil bulb & the shift bulb.
Old Aug 14, 2011 | 11:14 AM
Sweet 90's Avatar
Sweet 90
My windows are tinted and have not experienced what you have. By any chance, was your car an export car which would have the auto headlamp feature?
Old Aug 14, 2011 | 11:34 AM
ßill's Avatar
ßill
Churchkey - Pm will be sent in a minute, Thanks
Sweet90 My car is not an export model, but good thought. There is an ambient light sensor on the dash just above the inst/ave button. If you put your finger over this sensor you will see my problem.
Old Aug 14, 2011 | 12:02 PM
Sweet 90's Avatar
Sweet 90
Just did it Bill, mine dims and as I move my finger away, it brightens up. If you open your door and let some light in does it brighten up?
Old Aug 14, 2011 | 12:20 PM
ßill's Avatar
ßill
Yes it does. Part of my problem is old eyes, nothing I can do about that. It dims enough to get my attention during the day. Last Wednesday evening I was coming home about sunset and the dash went out. It was about 90 degrees out so windows were closed and AC on. I could have brought the dash back up by turning the headlights on. But thought there must be a better way. I don't like the headlights up unless I need them (speed brakes).
Old Aug 14, 2011 | 12:25 PM
Sweet 90's Avatar
Sweet 90
I hear you there Bill Maybe you just need a passenger to shine a flashlight on the sensor while driving. Hope Churchkey's solution works for you.
Old Aug 14, 2011 | 12:38 PM
ßill's Avatar
ßill
I recently read about polarizing film on the earlier "star wars" dash to correct problems but nothing about our dash. I hope it helps. Unfortunately I don't always have a passenger it hold the flashlight!. I have another idea that I will try as well. I will put a resistor in parallel with the sensor, This should lock the minimum dash light intensity. We shall see.
Old Aug 14, 2011 | 12:41 PM
Sweet 90's Avatar
Sweet 90
Knowing what ohm resistor will be the key. If this helps, to defeat my auto headlamps it was a 100 ohm resistor
Old Aug 14, 2011 | 12:49 PM
ßill's Avatar
ßill
The plan is to start about 50K. The problem is it is a pain to get to it! And more than likely not much room!
Old Aug 17, 2011 | 12:27 PM
ßill's Avatar
ßill
I tried paralleling the ambient light sensor with a 42K resistor (found in the junk box). I haven't had the car out at twilight yet but I think the results will be positive. During the day with sunglasses on the speedo was much easier to read. Snail mail is so slow, I'm waiting for the package from Churchkey More commentary when his contribution to this experiment arrives.
Old Aug 17, 2011 | 01:46 PM
jnealg's Avatar
jnealg
why not solder some clips onto a potentiometer (radio shack) and fool with it a bit until you get the right response then measure the pot to see what resister you'll need?
3 bux and you wont have to buy a bunch of resistors and change them out.
Old Aug 17, 2011 | 02:04 PM
ßill's Avatar
ßill
Calculated that aprox 50K was what was needed. 42K was what I found in the junk box. Close enough, and looks good. Zero dollars.
Old Aug 17, 2011 | 02:17 PM
Churchkey's Avatar
Churchkey
Sent at the PO Monday morning. I can attest to the fact that the PO still delivers bills & ad papers. Hope it still delivers snail mail.
Old Aug 17, 2011 | 02:31 PM
ßill's Avatar
ßill
We sure do get a bunch of junk don't we. They can keep the bills and the junk! just send the good stuff. Mail here is normally about 3 PM, it will probably be here this afternoon. Did you cover the whole panel or just the speedo area? Thanks again, I'll let you know how it works.
Old Aug 17, 2011 | 04:14 PM
Churchkey's Avatar
Churchkey
Covered the entire orange screen with the film. The fuel gauge bars are now distinct as well as the avg mpg/reserve readout & can now be read when wearing sun glasses. My eyes have also been around for a long time.
If any ?? on the install pm here, call or use the email addy I included with the brief install instructions.
Old Aug 17, 2011 | 04:40 PM
ßill's Avatar
ßill
Sounds like we are in the same boat. I'll keep you posted
To ’90 dash light?
