Radio problem/question
Old Aug 17, 2011 | 08:17 AM
chevytbss's Avatar
chevytbss
Default Radio problem/question
I have a 1987 corvette. obviously. The radio is acting strange. All speakers work fine. I have to hit the radio sometimes for it to even work..
The antenna only goes down once in a great while.... Why is that?
I took apart the dash and when i put the antenna on the radio it worked fine. once i turned it off and back on it messed up all over again..
Do i need to have it rebuilt?. I know i can put an aftermarket one in there but i want to keep it original. and pioneer/alpine is not original..
Do I have the option of putting a newer c4 radio in there with the cd-player will that work?
Old Aug 17, 2011 | 08:29 AM
silverja's Avatar
silverja
Default Some Helpful Information
http://forums.corvetteforum.com/c4-g...ied-audio.html
94-96 Camaro Bose CD player bolts right in, and there is a wire harness adaptor made just for the conversion. There are several on Ebay right now under Camaro Bose CD player. If you go to www.carstereohelp.com then click Corvette, then How to trouble shoot, then 1989 and older, it will show you what Bose radio, and they even have the adaptor harness forsale. The site is a big help. Hope this helps you out. I won one on Ebay a month ago, complete gone over, with a new NOS face plate for $200. It looks like new, but I haven't installed it yet.
most 90s GM radios WILL FIT....but the '93-'96 Camaro Bose CD is almost stock looking, lights even match when on.....keep the ***** from your original radio and put them on the new CD radio and it will look even better...I have one in my '85 and one in my '86....work great.
Best of luck.
Old Aug 17, 2011 | 08:31 AM
chevytbss's Avatar
chevytbss
That is exactly what i wanted to hear!!! Thank you so much!!. But will that correct my antenna problem as well?
Old Aug 17, 2011 | 08:38 AM
chevytbss's Avatar
chevytbss
could i put my 03 trailblazer radio in there/???
Old Aug 17, 2011 | 09:26 AM
silverja's Avatar
silverja
Default Not sure about the antenna issue
Antenna issue is very common. It looks like your antenna mast may need replaced. Check out this link with many discussions for some advice on antenna issues:
http://forums.corvetteforum.com/sear...rchid=25683385
Best of luck.
To Radio problem/question
