wipers
Old Aug 20, 2011 | 05:23 PM
gillt1's Avatar
gillt1
Default wipers
Hi all, my .95 coupe's wipers only work on standard or hi speed, no intermittant,will not pump washer fluid and wipes past A pillar What to do Thanks in advance
Old Aug 21, 2011 | 05:05 PM
Larry/car's Avatar
Larry/car
Sounds like two separate problems. I suspect the switch or wiring that controls the intermittent and pump. The wipe area, suspect mechanical indexing the blade. Try applying DC power dirrectly to the washer pump to test operation.
