LT-1 Engine id
Old Aug 21, 2011 | 03:03 PM
Raidmagic's Avatar
Raidmagic
Default LT-1 Engine id
Hey all, my buddy just picked up this motor and we can't find anything on it as to what it came out of, we've googled the numbers but nothing of any help other than it's an LT-1 from 94-96.
Anyone have any ideas?
The numbers are as follows:
10125327
327
H-8
588
These are the only numbers on the motor. Any help would be great.
Old Aug 21, 2011 | 03:32 PM
1963SS's Avatar
1963SS
OK, I'll try.
The 327 on the block indicates that it is a LT1
If there is a vent on the Optispark then it is a 95 or a 96. If no vent then it's a 94.
If the timing cover has a crankshaft position sensor then it's a 96
If the heads are Cast iron it's from a Chevy Caprice or an Impala SS 1994-1996.
Aluminum heads it will be from a F-body or a Vette.
4 bolt mains it will be a Vette engine.
Hopefully some sequence of the above will tell you what it is.
Old Aug 22, 2011 | 08:07 AM
Snipescastle2's Avatar
Snipescastle2
Default LT1 info
Did your block have a VIN # stamp on it? I bought a 95 LT1 a while back and it didn't have a VIN# at all, come to find out, it was a GM replacement warranty engine, four bolt Main to boot!
Have a good one!
Ben Smith
Old Oct 6, 2021 | 12:46 PM
BIGMAN - 79's Avatar
BIGMAN - 79
Cruising
WOW
What a great find and thread lots of great information like always.
I've been bit by the Corvette bug for sure.
Thanks to you guys in the know I'm very impressed with the info.
What a great looking Corvette, big thanks for sharing
BIGMAN
To LT-1 Engine id
