Hi Everyone!
I'm very new to this site and Corvette. I just purchased a 1984 Manual trans Corvette. I opened the Hood to check all of the fluid levels, and found all of them filled, except one. It isn't labeled, but is on the driver side firewall. Could anyone tell me what it is for, and what kind of fluid that I need to fill it with.
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
Sounds like your brake master cylinder but an 84 has 2 plastic reservoirs. Is it mounted to a large round black tank on the firewall? Oh, I see it's a stick shift-may also be your clutch cylinder.. Pix would help.
Here's a pic showing the brake master cylinder on an '85. If the reservoir you're asking about is underneath the brake booster, it's the clutch master cylinder and uses brake fluid.
My '84 has another smaller reservoir closer to the driverside firewall.
I've never had a 84 but on my 93 thats where my clutch reservoir is. If you could post a picture that would take all the guess work out of this. I know one of the guys would know right away what it is with a photo.
Bolted to the firewall, above the battery is the clutch master cylinder. DOT-3 brake fluid is the stuff. Notice too the color of the old fluid... If it is dark, and especially if there is some black flecks floating around or a black coating on the bottom of the reservoir, you'll want to purge the system.
