suspention question. pic inside
Old Aug 29, 2011 | 11:36 AM
hitmanpty's Avatar
hitmanpty
Default suspention question. pic inside
I got my 1986 corvette last saturday. I spend all day just going over the car. to see what need to be done.
one thing that call my atention.was the front suspention.
the front of the car is way to low. and the rear suspention look way to hi. or maybe is the efect of the front suspention been to low. that make it seen that way
any way my question is. if the front suspention supost to be that low???. or there is something wrong ???? (the car have new front shocks.)
please see picture. and tell me waht you think
[IMG][/IMG]
Old Aug 29, 2011 | 11:58 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Gravity plus 25 years have lowered your Vette. It may also has been lowered but, it looks good like that. The rear can be lowered by buying longer bolts. Look into Mid America, they sell them.
whats up with that wing?
Old Aug 29, 2011 | 12:01 PM
Keystring's Avatar
Keystring
My car is the same way. Seems to be common.
It can be lowered but I haven't gotten around to it yet.
I wouldn't worry about it.
Old Aug 29, 2011 | 01:10 PM
hitmanpty's Avatar
hitmanpty
the problem is that the car is to low for me. if I pass a spend boop at slow speed the lower part of the car will hit the concret. I thing if I change the fiberglass front spring it will solf the problem. dont know please let me know what you think
Old Aug 29, 2011 | 01:11 PM
hitmanpty's Avatar
hitmanpty
I just got the car last saturday. and it came with the wing. Iam not to creazy about it. but I think I can get use to it
Old Aug 29, 2011 | 01:26 PM
3D87C4's Avatar
3D87C4
Yeah, they are pretty low & your car may have been lowered, it's hard to tell from a picture. On most bumps the part that's scraping is plastic and can be replaced.
There is an air-shock system for sale at Corvette Central, but it's expensive and I haven't seen any posts from anyone who has it.
Old Aug 29, 2011 | 02:49 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
I'd suggest a new front spring, yours is either very worn, or could be broken. I'd get it in the air and check the front spring for any cracks. It is common to just have them start to sag over the years, though.
Old Aug 29, 2011 | 03:52 PM
navy_vette's Avatar
navy_vette
Those damn things tend to part and go bad. Mine has a nice crack running across it now. I'll be replacing it soon....
Old Aug 29, 2011 | 07:49 PM
turbotim23's Avatar
turbotim23
I'd first try adding the longer lowering bolts in the rear and adjusting the rear height down. You could do this in just a couple of hours, very easy to do. If that doesn't help try adding a little more rubber underneath front spring ends to raise the front of car a little. this could be done by simply zip striping the added rubber on under stock spring ends. I found my car to be very uneven so I adjusted all 4 corners the way I wanted them. You do have to come at bumps at a slight angle if you know they are coming to be safe and keep from hitting as much. Good Luck Tim
Old Aug 29, 2011 | 07:57 PM
professorX's Avatar
professorX
It's that ugly spoiler, you car is trying to shake it off that is why it looks like that.
Old Aug 29, 2011 | 09:02 PM
mike100's Avatar
mike100
I raised my car up in the front also because it scraped too easily.
read this thread- I put good pics in it:
Click here
basically you can lower the front by trimming the rubber mounts molded to the spring and by removing the spring shims above the rubber mounts.
You can add rubber (kind of) to fatten it up, but putting a shim or two in place also raises the car a lot.
Old Aug 29, 2011 | 11:40 PM
littlesk8cracker's Avatar
littlesk8cracker
definitely shouldnt be sitting that low, id check the front spring as suggested.
Old Aug 29, 2011 | 11:50 PM
cv67's Avatar
cv67
St. Jude Donor '05
Hes had the car like 2 days.
Old Aug 30, 2011 | 12:16 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
The wing will compensate for the low nose at speed.
Get a set of long bolts for the rear and drop it one inch.
It will take a few attempts to get the right amount of drop AND keep the rear level.
Not to worry you can't do anything wrong. Heck, you don't even need to jack it up if your less than 200 pounds.
Take your measurements from the fender lip to the ground on a level surface. Use the center of the axle as reference. Drive it a few hundred yards in between adjustments. Since your dropping the rear the nose will lift so keep measurements on front and rear.
I shopped around and found some grade 8 bolts that were 3" longer than the factory, at a hardware supply shop and fibrelock nuts to match. This ain't rocket science, so all that's needed is longer bolts.
Old Aug 30, 2011 | 01:43 AM
littlesk8cracker
i cant see anyone going through the trouble of lowering the front, and then leaving the back all jacked up like that being as the back is a million times easier then the front. im going with the worn out front spring
Old Aug 30, 2011 | 02:35 AM
JrRifleCoach
Most owners will not be ready to go thru a front spring change.
However most can handle swapping out the rear bolts.
Not saying this is the best fix. But if the front spring is not split or shattered, why not make a simple adjustment and continue motoring?
BTW You ever get tires for those wheels?
Old Aug 30, 2011 | 09:37 AM
hitmanpty's Avatar
hitmanpty
Hi every one thank you for all your feedback. First of all I will have to visualy inspect the front fiber srping. I think that is the problem. if I confirm front spring is damage. I will replaced . I dont like the idea. of modify the perfect condition rear suspention. to compensated for a damage front suspention.
Old Aug 30, 2011 | 09:38 AM
hitmanpty's Avatar
hitmanpty
Click here
Old Aug 30, 2011 | 01:07 PM
littlesk8cracker
i agree, might as well fix it the right way rather then half-a$$ it just to make it look acceptable
To suspention question. pic inside
