valve question?
Old Aug 29, 2011 | 12:26 PM
ETRBUJ1984's Avatar
ETRBUJ1984
Default valve question?
How much should i pay for a intake valve adj.? I know i need to have it done but just want a ball park to know what i need to save.
Old Aug 29, 2011 | 12:35 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Probably around $200. What makes you think you need an intake valve adjustment? Not to common these days, and generally means other troubles on an older engine.
Old Aug 29, 2011 | 12:47 PM
ETRBUJ1984's Avatar
ETRBUJ1984
im getting a clicking that i think is from the lifters would a valve adjustment help, maybe it can quite them down?
Old Aug 29, 2011 | 01:18 PM
zr1fred's Avatar
zr1fred
It is probably one of the easiest jobs to do on an 84, not much harder than replacing the valve covers (very common). You might try it yourself. Try tightrning them 1/4 to 1/3 of a turn. If it still makes noise, you have other problems (Bad lifter or cam). Additives often work on engines that don't get driven much.
Old Aug 31, 2011 | 10:49 AM
ETRBUJ1984's Avatar
ETRBUJ1984
So just tighten thats all? And what additives like sea foam or something of that sort?
Old Sep 1, 2011 | 08:25 AM
Muffin's Avatar
Muffin
Go to Harbor Freight( or any parts store) pay $5.00 for a mechanics stethoscope. Spend some time listening to each cylinder through both the intake runners and the exhaust. Listen for differences in sound. I wager you will find the offending lifter, if it is a lifter. Also listen to each injector. Injectors have a click that can become quite loud.
Old Sep 1, 2011 | 09:40 AM
cv67's Avatar
cv67
St. Jude Donor '05
Bet what youre hearing is fuel injectors, they make noise as Muffin said.
Perfectly normal.
hydraulic lifters rarely if ever have to be adjusted.
If youre going to do them do all of them and no you dont just tighten them down.
Stethescope then go from there.
Old Sep 1, 2011 | 10:16 AM
1963SS's Avatar
1963SS
BTW, Harbor Freight has their electronic stethoscope on sale. I thought it was a gimmick but I tried one anyhow. It comes with different length probes and a set of headphones. It's great for filtering out background noise and is very, very sensitive. It has a sensitivity/volume control rheostat on it and works just great. I'm never going back to my old one.
Old Sep 1, 2011 | 12:11 PM
Muffin's Avatar
Muffin
Thanks for the 'heads up".
Old Sep 1, 2011 | 12:43 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Stay away from oil additives.
-They are snake oil
-They claim to do what oil already does.
To valve question?
