Need help installing boot(s) on switch
Have any of you done this? The only access I can see is with the door open and do it from the outside. How do I keep the switch from falling into no where land? I have a 1987 stock convertible.
Kistler
Looking at the door ajar switch part listings on the Corvette Central I notice a couple of things. First, they show a door ajar alarm switch striker as being located on the door jam consistent with the switch in the door. Second, the pictures of the door ajar switch itself shows a flange with what appear to be two mounting screw holes suggesting how it may be attached to the frame. From this I wonder if maybe the '87 was some kind of transition year & maybe this is better documented in an earlier years FSM---forum member Agent86 regularly posts figures from the '86 FSM and might be helpful. Finally, if I'm correct about how the switch itself is mounted (i.e. 2 screws through the flange) then you probably don't have to worry about it falling free. I'm guessing, at this point, the boot is just press fit into the opening---yank the old one out & shove the new one in.
Hopefully someone who's done this will respond. These guy's might be worth contacting as well:
http://forums.corvetteforum.com/c4-p...warehouse.html
I was thinking of taking my needle nose pliers and gripping the post of the switch while taking an end wrench to loosen the hex nut/tap.
The danger (and there are several
) is my dropping the switch inside the body and it will be gone forever.Getting the new boot on is going to be tricky as I will have to take the vice grips loose to get the boot behind the washer......
May be I should return the boots and just never drive in the rain; it hardly ever rains here anyway.
Kistler
It turns out there are two switches---the door ajar switch and the door jam switch (courtesy light switch - front door jamb 594301 at Corvette Central). Both use the same boot, fortunately.
If you look at the door jamb switch picture it threads into the jamb & the hex head is how you grab it. So, no problem with it disappearing into the frame.
One last thought...
Take some pictures when you replace it & post 'em here or in a seperate 'how to' thread---wouldn't you have loved to find one when you started this thread?
I really appreciate your time and help.
Kistler (aka Larry Ryan)
The FSM info I got from my copy of the book.
The picture of the door jam switch (which really tells all you need to know) is on the Corvette Central web site:
http://www.parts123.com/parts123/yb....~Z5Z5Z50000050
As for the search function, I searched the C4 section for door ajar switch and found lots of threads. After reading 5 or 6 I found one that mentioned there are two switches & the one you're working on is the door jam switch---not the door ajar switch.
