C4 window fogging up
Old Sep 5, 2011 | 05:03 PM
rdsxfn524's Avatar
rdsxfn524
8th Gear
Default C4 window fogging up
The window is fogging up on the outside as the car is running so im trying to figure out what is wrong can somebody help me, its a 96
Old Sep 5, 2011 | 06:05 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
What is your inside temp set at? What's the outside temp? What setting is your climate control set for?
Old Sep 5, 2011 | 07:35 PM
torchred89's Avatar
torchred89
Better then on the inside smelling like coolant!
Old Sep 5, 2011 | 07:48 PM
jimmers's Avatar
jimmers
Old Sep 5, 2011 | 08:05 PM
c4speed's Avatar
c4speed
From: Atco Raceway in between Pa & Nj 13.073 @ 106 MPH
heater core
Old Sep 5, 2011 | 10:16 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by c4speed
heater core
Probably not for outside fogging. I'd guess the car is parked where it's cool and possibly a hair damp. Maybe outside?
It might also be missing all or part of the cowl seal. So, when the engine is started, hot air floats out the cowl and hits the cool outer windshield.
My does this when parked outdoors because of the large cowl cutouts in my Toledo Pro Hood.
Old Sep 5, 2011 | 10:17 PM
GREGGPENN's Avatar
GREGGPENN
D@mn right. Fogging on the inside (especially if smelling like coolant) means your heater core has sprung a leak.
Old Sep 6, 2011 | 02:34 PM
rdsxfn524's Avatar
rdsxfn524
8th Gear
I finally got to see it last night cuz its my dads car and the fogging starts right at the center so im almost positive that its just the window getting cold right there and hot air opposing it or something of the sort...is this a normal concern for these cars?
Old Sep 7, 2011 | 01:27 AM
Klondike's Avatar
Klondike
Is there any cold A/C air coming from the defroster vent in the center of the windshield? I can make this happen if I put my A/C on the defrost or the split level between floor and Def. The outside of the window will get a little foggy spot on it like the outside of an ice-tea glass does when you go outside in the heat of the day. The glass is just getting cold in that spot.
Old Sep 7, 2011 | 01:33 AM
rdsxfn524's Avatar
rdsxfn524
8th Gear
yes there is cold air coming out of the defrost vent and apparently sometimes the a/c doesnt do what he wants so im thinking the mode doors might have a problem
Old Sep 7, 2011 | 01:49 AM
Klondike's Avatar
Klondike
Yep, mine did that. Sometimes it took forever for the air to finally come out of the dash vents. It was vacuum leaks in that little vacuum router box under the dash above the gas pedal. A real "mother dog" to get out, but fairly easy to fix once you do. There is a detailed post w/ pictures here some place, just can't think of what the title of that post is.
Jump in here guys, I'm sure somebody knows where this fix with pix is located.
Old Sep 7, 2011 | 11:52 AM
rdsxfn524's Avatar
rdsxfn524
8th Gear
Exact same problem it takes a minute for the air to come out of the vents so if somebody can find that it would be great
Old Sep 7, 2011 | 11:56 PM
primalurges's Avatar
primalurges
bump this up, same problem here
Old Sep 8, 2011 | 02:34 PM
Klondike's Avatar
Klondike
ttt
Old Sep 8, 2011 | 03:37 PM
rdsxfn524's Avatar
rdsxfn524
8th Gear
think i found it in three threads http://forums.corvetteforum.com/c4-g...ue-1996-a.html
http://forums.corvetteforum.com/c4-g...t-defrost.html
http://forums.corvetteforum.com/c4-g...r-removal.html
Old Nov 10, 2011 | 01:42 AM
cheftony's Avatar
cheftony
2nd Gear
Default worried about my new 92 c4, coolant inside?
So I went on a short ride tonight (first time on highway really...just got the car recently..) and seeing a lot of fog inside car...almost all four windows...couldn't get rid of it...
and it seemed like not normal fog, but something more sticky... or slick...
then after about 40 minute ride, on way back home "service engine soon" light came on. UBER WORRIED NOW.
and earlier today, when I closed my restaurant and picked up car, there was a leak in the public lot that did seem to come from my car...
Heater core leak??
If that's it, what kind of $ am I looking at to fix, and can I drive it to shop? All gauges seemed to be running fine on way home, with "service engine soon" light on of course..
Help??
Old Nov 11, 2011 | 02:56 AM
rdsxfn524's Avatar
rdsxfn524
8th Gear
that definitely sounds like a heater core problem which from what ive heard is a pretty penny to fix i think you have to take the dash out and all that good stuff good luck.
To C4 window fogging up
