ajusting front suspension
Old Sep 6, 2011 | 05:06 PM
hitmanpty's Avatar
hitmanpty
Default ajusting front suspension
Ok maybe is an stupid question. but Iam going to ask any way.
is there a way to ajust the front suspension in order to lift the front end a little more
Old Sep 6, 2011 | 05:08 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Yes, there are two ways I know. Do a search and find the pictures and ways to do it.
You can add shims to the monospring brackets or rubber bumps to the tips/end of the monospring.
Old Sep 6, 2011 | 05:15 PM
hitmanpty's Avatar
hitmanpty
thank you. that is good news. can any body pointme to the right direction on this. I been doing some searching and I not finding anything. about this.
Old Sep 6, 2011 | 05:21 PM
hitmanpty's Avatar
hitmanpty
I just did a search in goggle. for ajusting corvette c4 front suspension. and in the second page I found this very same post. can some body help me on this. need more info about this matter
Old Sep 6, 2011 | 05:30 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
Check to make sure your shocks are good. Mine were busted/weak and when I installed new shocks the front end came up over 2 inches. I had marks in my wheel wells from the tire rubbing when I went over a few big speed bumps.
Old Sep 6, 2011 | 05:34 PM
hitmanpty's Avatar
hitmanpty
the shocks are new.
Old Sep 6, 2011 | 05:57 PM
hitmanpty's Avatar
hitmanpty
the shocks are new.
any body. how do you ajust the front suspension
Old Sep 6, 2011 | 05:58 PM
3D87C4's Avatar
3D87C4
I did a search of C4 for "raise front end"---not many usefull responses.
VBP has an adjustible front spring that is compatible with late model C4's.
Here is a do-it-yourself thread that works on the same principal:
http://forums.corvetteforum.com/c4-g...djustable.html
You might want to read a few lowering threads. The suggestions above are basically a reverse of what folks do to lower it---adding shims etc. to raise it instead of removing them to lower it---& will make more sense after reading some lowering threads.
Old Sep 14, 2011 | 01:35 PM
3D87C4's Avatar
3D87C4
Have you been following this thread?
http://forums.corvetteforum.com/c4-g...ir-shocks.html
Old Sep 14, 2011 | 05:42 PM
anciano's Avatar
anciano
I wish like hell I had added some shims to raise mine when I was in there, but I was hoping that replacing a cracked spring with a good one would add some lift. I asked this question before but got no responses: how many shims have other owners found in their OEM 94+ front brackets? I only had one on each side, and it doesn't seem to be enough.
I guess the easiest method to get more front clearance would be to lift the front end of the car, put a floor jack under the spring ends to lift them off the a-arm and then insert some sort of spacer (rubber or otherwise) under the existing rubber spring tip. If a metal spacer it could probably be secured in place on the a-arm with JB Weld or 3M 5100 adhesive.
Old Sep 15, 2011 | 03:46 AM
rodj's Avatar
rodj
Originally Posted by anciano
I guess the easiest method to get more front clearance would be to insert some sort of spacer (rubber or otherwise) under the existing rubber spring tip.
http://forums.corvetteforum.com/1569542291-post33.html
http://forums.corvetteforum.com/1568125259-post17.html
Old Sep 15, 2011 | 07:36 PM
gerardvg's Avatar
gerardvg
You can install coil over shocks with weak springs to raise the front, keeping the standard composite spring
(booster springs i believe they were called)
then you can adjust ride height with the coil over adjust tool.
Later you can go coil overs only, and remove the composite springs and install the correct coil over springs for your vette.
Just a suggestion as this is what i did first before going all out to coil overs only.
Gerard
To ajusting front suspension
