Some how the wire was cut or broke on the brake fluid level switch (Master Cylinder)
Where is the location that the wire go to?
Can't seem to locate the other side of the the broken connection
I'm working with a 90 ZR1. I'm sure its the same for all models.
A pic may work too...
Reg C4's (<'90 at least) don't have a brake fluid level switch.
The switch in the side of the M/c is for fluid loss in front or rear brake system.
The piston in the proportioning valve on side of M/c moves one way or the other from central position activating the switch if it is out of balance
