air cleaner box 84 vette
there is a rubber gasket in the bottom of the box that needs replaced. the box and related gaskets were discontinued. can someone suggest a solution on making one?
jeez, prices are high. TB rebuild kit i got from autozone a couple years ago had a set in it along with all the goodies to rebuild the TB's
I had to run out and check mine before i put my foot in my mouth...
Actually at the TOP of the box, if you're holding it upside-down to look inside, there is an outer narrow one and the inner one is a flatter, wider seal. I assume it is the wider you refer to? It seats against the air cleaner rubber. They might be hard or impossible to find. I suggest going to Big Five and check out the cheapest thinnest sleeping bag foam mat-it's about the right thickness. Cut it so it fits in there and there's still room to trim it down to the right size. Once the box is tightened down, I don't believe you'll have any leaks.
Both mine are ok but my neighbour's thin seal was rotted out on his 84, so I used a piece of the right-sized vacuum hose to fill it in. Been good for 4 years.
air cleaner box gasket
hey Squirmin you ain't no vermin. vacuum hose i could not think of a material that would not break down. excellent and if i split it top over bottom to overlap,no leak! thanks
airbox
we don't have a big five in east tennessee, but is the sleeping bag material foam or rubberized. i thought of weatherstrip like on the t-top
for the bigger gasket? i appreciate your input.
Any sporting goods store should have those roll-up sleeping mats and the cheap ones look close to the right thickness. Either foam or rubber. Flat weatherstripping might work if the thickness is right. I suggested a flat mat as flat weatherstripping may be hard to bend into the required curves needed without twisting or curling. Just cut the shaped pattern out of the mat. All it does is provide a seal for the top of the air filter to the box lid.
