Installing new boot on courtesy light switch
Old Sep 8, 2011 | 06:44 PM
Jayhawk62's Avatar
Jayhawk62
Default Installing new boot on courtesy light switch
I unscrewd the hex nut; actually the whole switch is threaded and came out
Took the plastic connector apart; it is slotted so easy to plug back together correctly
The job is completed AND the lights still function--unbelievable!
Old Sep 8, 2011 | 08:42 PM
3D87C4's Avatar
3D87C4
Good job!
Old Sep 8, 2011 | 08:44 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Old Sep 8, 2011 | 08:56 PM
Jayhawk62's Avatar
Jayhawk62
Thank you fellows The driver's side actually was easier; the hex nut loosened more easily and the switch itself was not screwed in as far as the passenger side so there was less twisting of the three wires. I am lucky they did not pull out of the plastic of the switch.
The plastic switch and its "companion" insert are/were notched so I couldn't go wrong in the re connection of the two parts.
I should have ordered a tab/**** for the fuse box; you probably noticed it is missing from the fuse box door?????? How does one lose that?
Any ideas on a glue that will bond the kick panel (showing foam rubber backing) to the plastic door. I am fast developing a glue collection Super, Gorilla, etc......
Kistler
Old Sep 8, 2011 | 10:11 PM
mrmtrtrnd's Avatar
mrmtrtrnd
I'm no help on the glue because most that I've tried don't work as advertised.
To Installing new boot on courtesy light switch
