Dash light ?
Old Sep 9, 2011 | 02:41 PM
Jayhawk62's Avatar
Jayhawk62
Default Dash light ?
My oil pressure/oil temperature gauge is not lighted; it even gets harder to see on "off". Do I need a bulb or an LED?
Old Sep 9, 2011 | 03:17 PM
Goldcylon's Avatar
Goldcylon
Prob the backlight blubs for the display. Suggest replacing them all after you pull the cluster. GC
Old Sep 9, 2011 | 03:23 PM
Jayhawk62's Avatar
Jayhawk62
Thank you for replying; I should be glad if it is a bulb and not an LED. I was reading about sending your dash display into Corvette Central for repair.....that is a bit costly.
I hope someone will advise me on doing the dash removal/bulb replacement.....
Kistler
Old Sep 9, 2011 | 03:51 PM
Goldcylon's Avatar
Goldcylon
This might help you with your bulb decision
http://forums.corvetteforum.com/c4-g...l-bulbs-2.html
And the blub replacement procedure
http://forums.corvetteforum.com/c4-t...ght-bulbs.html
GC
Old Sep 9, 2011 | 03:55 PM
navy_vette's Avatar
navy_vette
I didn't even know they used any LEDs in this car.
Bulbs are easy. LEDs rarely go bad anyways. If one does, I can fix it. The worst an LED replacement can be is removal and resoldering. I do that for a living.
Old Oct 1, 2011 | 05:50 PM
Papersen's Avatar
Papersen
FWIW, the bulbs are GE 882X or GE 18167's. I thought I ordered the correct ones (2 different places) off the internet and am still looking. First (ebay)was supposedly for 86 thru 89 but were actually for the 89 - earlier are bi-pin vs. wedge base for 89. next I ordered xenon type per someone elses recommend on the forum, and the lamp is too long by 1/4". The specs are 5W, 12V, T2-1/4, bi-pin, OAL ~1.00 inch. I will try the local auto parts as others seem to have found them. Inst Panel is very easy to remove per Goldcyclon's link.
Old Oct 1, 2011 | 06:39 PM
navy_vette's Avatar
navy_vette
There are kits you can get that have every single interior and dash bulb in your car specific to your year set. I think the one I was looking at was at Ecklers. Not sure.
To Dash light ?
