c4 power steering problem
Old Sep 12, 2011 | 04:34 PM
DAGS123's Avatar
DAGS123
5th Gear
Default c4 power steering problem
lost all power steering fluid in the well. replaced the fluid but still have the noise when moving the wheel to either side. can you help troubleshoot this problem? thank you!
steve (sdagz@aol.com)
610-642-8706 philadelphia
Old Sep 12, 2011 | 04:49 PM
Muffin's Avatar
Muffin
Need more details. Power steering fluid in the well? Am I missing something here? Can you see a leak? Hoses? Leak from pump? Belt? After refill did you turn the steering wheel from lock to lock several times to purge all air? Would also help to know what year.
Old Sep 12, 2011 | 04:55 PM
DAGS123's Avatar
DAGS123
5th Gear
i sincerely appreciate your prompt response. i don't know what you mean "from lock to lock". i did turn it part ways but was afraid to turn it all the way to end on each side because of the noise it made. should i?
also, i can seem to find where the leak is coming from? the belt is still good. this is a 1985 corvette. moreover, i can find the leak in the hose or pump because i don't have a lift.
thank you for questions.
feel free to copy your post to my email at sdagz@aol.com
Old Sep 12, 2011 | 04:57 PM
DAGS123's Avatar
DAGS123
5th Gear
also, i cant seem to locate where the leak is coming from? the belt is still good. this is a 1985 corvette. moreover, i cant see if the leak is in the hose or pump because i don't have a lift.
feel free to also send response to my email at sdagz@aol.com.
where are you located?
To c4 power steering problem
