C4 windows slow? Is this normal?
Old May 1, 2002 | 03:40 PM
Meeko87's Avatar
Meeko87
Default C4 windows slow? Is this normal?
I bought my 87 about 3 years ago and the windows have always been slow but I didn't pay any mind to it untill I test drove a collectors edition the other day and noticed the windows roll down at light speed is this normal for early C4s to be slow or is it just mine? Never had a problem with them not going down motor seems fine but, kinda slow. Can anyone relate?
Old May 1, 2002 | 03:50 PM
vettackular's Avatar
vettackular
Default Re: C4 windows slow? Is this normal? (vettemanjoe87)
my 84 has a similar problem. The driver side will go up and down with the blink of an eye, but the passenger is SLOW, nothing wrong with the motor that I can find but definately slow!
JonM's Avatar
JonM
My 84 before I upgraded to 86 windows was slow as a turtle swimming upstream. Even upgrading hasn’t made them lighting fast, but adequate.
Old May 1, 2002 | 03:53 PM
-=Jeff=-'s Avatar
-=Jeff=-
when I replaced the outer window seals on my 89 they sped up. I think over time the felt pads wear down and cause more friction and resistance to the window moving
Old May 1, 2002 | 03:56 PM
Kale's Avatar
Kale
I cleaned up the tube on the windows, and sped them up a LOT, but they are still slow.
Old May 1, 2002 | 04:46 PM
ZR_TO_ENA's Avatar
ZR_TO_ENA
I had a similar situation on my 86's passenger's window. I tried to clean/lube but no major change took place. Finally I just got used to it.
--john
Old May 1, 2002 | 06:43 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: C4 windows slow? Is this normal? (speedwise86)
I disaasembled everything including the motors and cleaned and lubed everything. Now mine goes up and down with lightning speed compared to what it was like before the maintenance. :cool:
Old May 1, 2002 | 08:28 PM
IceDigger's Avatar
IceDigger
Default Re: C4 windows slow? Is this normal? (Sharky Guam)
My passenger side window goes up and down alot faster then my drivers side. Even still it is slow. :(
Old May 3, 2002 | 10:18 AM
GiDvEtTe84's Avatar
GiDvEtTe84
Default Re: C4 windows slow? Is this normal? (IceDigger)
My pass side window has an aftermarket motor and regulator. It cruzes!! The only thing is that it doesnt go up all the way unless i open the door, it hits against the weather stripping and leaves a crack in the back. How do i adjust it?
Old May 3, 2002 | 02:33 PM
Justin1984's Avatar
Justin1984
mine are both equally slow. I also have a 1989 Chevy van with power windows. They are just as slow.
Old May 3, 2002 | 02:38 PM
84corvette's Avatar
84corvette
Default Re: C4 windows slow? Is this normal? (Justin1984)
Both of mine are very slow --been that way since I bought it about 5 years ago.
(maybe I should try a little maintenance!!) :D
Old May 3, 2002 | 05:42 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: C4 windows slow? Is this normal? (84corvette)
On my 87, the windows go up FAST!!! I dunno WHAT they did, but in NONE of the receipts does it show that it ever had the window motors upgraded or changed..so I dunno. All I know, is I need new inner and outer window seals. (It makes the car look SO much better to have brand new ones) But I think they're tricky to install, so I'm waiting till I can have them done professionaly.
Old May 4, 2002 | 07:04 PM
ktriebol's Avatar
ktriebol
The raise/lower mechanism on early C4's was a **** poor design. It is a gear rack in ribbon form. Later C4's are far superior. GM knew this and made an upgrade kit available. I installed the upgrade kit on both doors of my 86 Vette. It worked great. I highly recommend them. It will take you about 6 hours to do one door, but it is not particularly hard, though. I think the kit cost about $100 per door. While you are at it, I recommend replacing the door handles so they look nice and new.
Old May 5, 2002 | 08:57 AM
dmalhi1's Avatar
dmalhi1
haha my buddy with an 86 vette says his roll up slow cuz the lil outer and inner window seals, "Form a really tight seal." hahahaha he doesn't want to admit that his motors are near fried.
haha my 89's are lightning fast!
Old May 5, 2002 | 07:46 PM
n1kki6's Avatar
n1kki6
My 94 windows are fast
Old May 5, 2002 | 11:29 PM
carter200's Avatar
carter200
If you are a window racer then you may have a problem but if the window goes up and down then what's the rub? :confused: Be glad the windows work at all :yesnod:
Old May 5, 2002 | 11:47 PM
GS 163's Avatar
GS 163
Default Re: C4 windows slow? Is this normal? (n1kki6)
To C4 windows slow? Is this normal?
