My factory original lasted 8 years. My new OEM factory replacement rusted out in less than 2 years. :mad I'd suggest going with stainless steel.
Very interesting! Our 87 still has the original, that's why I wanted to stay with GM. but hearing this I'll definitely look into stainless. The pipe is rusted where it enters the Borla muffler on the passenger side..
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Re: Need to replace rear Y-pipe (Hogs)
That sounds like a problem of dis-similar metals setting up a galvanic cell and corroding through. Either go with all stainless or all aluminized, don't mix metals.
Does "aluminized" pipe really contain any aluminum??
Thanks for the heads up!!
replaced the orig Y-pipe on my '88 today... longer life than any other car I've ever owned.
