Quick Brake Bolt Torque Question.
Ps. Any extra info on the process will help me! You guys always get me through my wrenching!!
and 1990 onwards to 166 ft lbs
The manual does say to put adhesive on the threads (most likely loctite) you can get varied strength from auto parts suppliers.
The bolts thread into guide pins and these pins should be pulled out, cleaned, and re-lubed. This is a specific lube you can get at parts stores and typically come in a small vinyl package. Inspect the pin and the rubber boot for any damage. The guide pins and boots are a common GM item and you can get them at parts stores.
The rear calipers are similar but the lower bolt is torqued to 16-18 ft-lbs. Remember to release the parking brake and pull the cable off the bracket on the caliper before removing it from the car.
If you are replacing the rotors, the caliper abutment brackets have to come off. The large bolts in front ate torqued to 165 ft-lbs ( +/- 15 ft lbs) and the rear bolts are torqued to 70 ft-lbs. Clean the threads on the bolts and apply Blue Loctite. In spite of what the FSM says, you can re-use the bolts.
But will be worth it.Jonathon
What it that?
If you have the GM FSM (Factory Service Manual) there should be torque specs on the last page of each specific section. Torque specs should also be noted in the detailed step-by-step instructions.
Also for all of the bolts, they can be re-used even though the FSM says to discard the bolts. These bolts require some sort of threadlocker to be applied to the threads. GM bolts from a dealer come with a threadlocker applied.
If you have access to a bench grinder with a wire wheel, use the wire wheel to remove all of the old material from the bolts. For the female threads, I like to use a 12 gauge shotgun brass cleaning brush and some non-chlorinated brakes parts cleaner. After cleaning everything, apply some BLUE Loctite to the bolt threads and install using the proper torque values
Thanks to all the others that helped with my questions
Jonathon
Next Project, Replace a/c. Have the parts just need the labor
