1991 VSS Question
Old Sep 23, 2011 | 11:59 AM
SMosley's Avatar
SMosley
Cruising
Default 1991 RPM Gauge Question
My 91, L98, six speed has a RPM gauge problem. When I turn the key to ON the RPM needle slowly moves upward, when I engage the starter the needle pegs at 6000, when the engine starts the needle drops to zero and does not move anymore. I bought a used cluster which the owner says worked fine but when I installed that I had similar problem. Help.
Old Sep 23, 2011 | 04:43 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
I'd say the problem is in the vss, mine has been acting up for some time now, the speedometer dosn't register untill i drive a couple of miles but then works fins
Old Sep 23, 2011 | 04:47 PM
The Green Hornet
Just re-read your post, guess a tach problem would be something else.
Old Sep 23, 2011 | 06:28 PM
SMosley's Avatar
SMosley
Cruising
It is the tach that isn't working. All my other gauges and the speedometer work fine.
To 1991 VSS Question
