Hi iam in the midel of this job now .
I have numer 1 spark plug out trying top put the harmmonig balancer on tdc . But every time the mark isla close top the tdc the number 1 piston isla not at the top . I crank the car cumple of times top make the harmmonic mark go 360 But same every time the materia is close the piston is down
what iam doing wrong here please advice
Sorry for the badajoz writting iam using my pone every hart top use
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Are you installing the old harmonic dampener?
If so, the rubber may be deteriorated allowing the outer ring to loose it's zero.
Time to buy a new unit.
Sounds like maybe the harmonic balancer mark is wrong. Focus on what is happening in cylinder 1. Get cylinder 1 to top dead center at the end of the compression stroke and check where the balancer and distributor are pointing.
using my pone every hart top use = using my phone very hard to use took me a bit to translate that
The harmonic balancer is not going to be "loose". It'll still be tight as hell, it'll just have shifted in one direction or another and give you a misleading indicator. We had to change ours in the 87' after I redid the top end.
I can feel number 1 cilonder at the top now distribuir roto is pointing to number 1 posición
harmmonic balancer mark most be pointing some where under the car because i don see it
Good. Now paint a mark on the balancer & you can set the timing.
The original mark has moved so you need to paint a new one. I haven't done this on a Vette but have on other cars...there should be some fixed indicator by the balancer mounted to the block. With number 1 cylinder at TDC, paint a white mark on the balancer at the indicator position. To check your timing you connect your timing light to the #1 spark plug wire and point it at the balancer. Every time #1 plug fires the light will strobe and you will see the painted mark. Setting the timing changes the relative position of the paint mark and reference indicator.
If your balancer is moving you probably need to replace it, but re-marking the old one should be good enough for now.
The good news is that, at TDC, the distributor is pointing to the right place. That's what you needed to learn from this experiment. Mark the balancer so you can check/set the timing, replace the plugs with the correct type & replace the plug wires if needed and hopefully you'll be able to get it started.
Thanx everyone for the help i will have to set the timmimg by ear
Good luck! You should follow the advice and paint the mark. Make sure that TDC is for the piston with both valves closed and not TDC for pushing the exhaust out on the final fourth stroke!
Absotively, posilutely.
Though I doubt it would have run at all with it 180 degrees out.
Reason: mis-spelled my intentional mis-spellings, d'oh!
I would say that the best thing to do is to get a new balancer and do it RIGHT as opposed to screwing around with band aid fixes
You're right, but look where he's at: Panama, South America! There might be a Chevrolet dealer there (maybe, maybe not) and there might be a new balancer, but even here, a lot of the early C4 parts are quickly becoming NLA or "No Longer Available". Nothing a little appliance paint can't fix
I would say that Chevy 350 motors are going to be common enough that we won't have a "corvette only" dampner and he might be able to get one. Still, If it turns, I would be leery to leave it on. No telling what else it might do.
