Swint
Old Oct 3, 2011 | 12:12 PM
flcarrell's Avatar
flcarrell
8th Gear
Default Need help with a mis in my '86 C4
I need help with a mis in my '86 early model corvette. 53,000 miles it has sat most of its live. I have used injector cleaner new fuel filter, air cleaner, spark plugs and wires cap and rotor. checked for vaccuum leaks sprayed MAF cleaner it already looked great. Octane booster even. I am running out of ideas. I see more light cumming though the plugwires with the ones than the old ones. I don't think i should see light at all should I ? Even the new EGR hasn't helped. It runs alittle worse each time i do something. What do i do next?
Old Oct 3, 2011 | 03:26 PM
dukeallen's Avatar
dukeallen
Go to a mechanic. And watch out for grammar *****.
Old Oct 3, 2011 | 03:41 PM
1963SS's Avatar
1963SS
OK, I've gotta ask......probably gonna be sorry. What's a "Swint"?
Old Oct 3, 2011 | 03:58 PM
bangbgC6's Avatar
bangbgC6
Starting
With
Ignition key
Not
Taking place
If I'm right what do I win?
Woman
In
Negligee
Old Oct 3, 2011 | 04:14 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
Originally Posted by bangbgC6
Starting
With
Ignition key
Not
Taking place
Woman
In
Negligee
Old Oct 3, 2011 | 05:00 PM
flcarrell's Avatar
flcarrell
8th Gear
Default Swint
Swint stands for South West Iowa Nature Trail.
Old Oct 3, 2011 | 05:53 PM
1963SS's Avatar
1963SS
Sorry, I guess we all should have known that. Back to your question....When you say you see light coming through the plug wires, do you mean they're arcing? If you look at them when it's dark do you see little flashes on the new plug wires also?
Old Oct 3, 2011 | 06:05 PM
flcarrell's Avatar
flcarrell
8th Gear
Thank you for the feed back. I have to learn this system. Anyway I do not see a arch or hear a snap just some light traveling in the wires in the dark. In the old days the wires would snap and shock the crap out of you. I don't have that. I was suprised to see any at all. They are new from ecklers
Old Oct 3, 2011 | 06:12 PM
1963SS's Avatar
1963SS
I hate to say but if you can see "light" inside the wires then something funny is going on. Electricity will only make light in a wire if something open and it's jumping a gap. Maybe it's some new-fangled wire or something but I have never, ever seen light inside plug wires. Maybe someone else will chime in with these new visible electric wires.
I once had a clear cap on my Dodge Van and you could watch the spark from the rotor. That was kinda cool but glowing wires....I want a set.
You might consider getting some Taylors or some OEM wires though just to be sure. I think the wires are shot.
Old Oct 4, 2011 | 04:46 PM
flcarrell's Avatar
flcarrell
8th Gear
I talked to Ecklers and they are sending more wires to try. I hope that helps. As we thought light is a no no.
Old Oct 4, 2011 | 04:59 PM
hooked073's Avatar
hooked073
Dumb question why would you buy wires from ecklers when any of your local auto stores should of had them? Nothing special about Vette wires. Just asken is all
Old Oct 4, 2011 | 05:11 PM
flcarrell's Avatar
flcarrell
8th Gear
No reason I had a speciality part coming and had them send some tune up parts is all.
To Swint
