I wish it did but.....no it doesn't. You've gotta pull the spring drop suspension to gt it off, cut wedges, glue on wedges etc. Lot of replies to this can be found in the search including at least on pictorial. It took me about 5 hours using a lift. But boy it does look better. It looked like a 4WD before compared to now.
You can buy longer rear bolts and that's all you need to lower it. It take about 30 minutes and is just as easy as changing out those 2 bolts. If you have a supply house around the size that would work would be 14mm x 280mm. Try to get the grade 8 bolts. They're harder.
the problem I have now. every time I step on the gas. not need to go all the way just regular driving. the rear sping very easy. I think is because the rear is to light weight. feel like I dont have a good grip in the rear
Many of the lowering kits come with a nylon locking nut. You don't need the drilled "security pin". You could also use two nuts to lock it if that bothers you.
the rear spring very easy.
I've not heard that too often. You may want to check your spring and shocks while you're under there changing the bolts. Something could be wrong. You need to get a good grip on your rear. Does it spin the tires pretty easily?
I'm glad you got your car running. Did the mechanic fix it? How do you like driving a Corvette? Does your wife let you go cruising all by yourself and look at the senorita's bonitas.
I can get nylon nuts here. I think I will use those. also I know my rear shocks are not good. a big clanking noice coming out of the top rear suspension.
reagrding driving a corvette.
yes spin the tires pretty easily I think too easily
