Pass side window adjustment
Old Oct 15, 2011 | 08:42 PM
vish2000's Avatar
vish2000
Default Pass side window adjustment
My 96 window does not come up even. seems the front side comes up further than the back side. any adjustment point?
Old Oct 16, 2011 | 09:14 AM
HlhnEast's Avatar
HlhnEast
Yes if you take your door panel off and have they window about 3/4 way up you will see 10mm adjustment nuts. You may have other issues like missing nylon rollers. Your just gonna have to take the panel off and see.
I have a .pdf of adjustment procedures and if you PM your email to me I will send it out to you.
Good luck!
Old Oct 16, 2011 | 09:25 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
There is a black plastic guide that is bolted to the bottom of the glass on the 90's, that also works as a stop. After 10 or so years, they break, allowing the front of the window to go to far up causing the window to "cam" and the back corner to hit the b pillar. Both sides. The only cure is to replace the guide. They're about $30 for either the left or right.
To Pass side window adjustment
