Resetting "Change Oil" indicator
Old Oct 20, 2011 | 07:48 AM
toptechx6's Avatar
toptechx6
One option here
http://www.ebay.com/itm/92-93-Corvet...item20bd705f43
Old Oct 20, 2011 | 08:54 AM
tim1's Avatar
tim1
Thanks for the lead toptech. I have been playing around with mine for about an hour or so and figured that some else had been inside the instrument cluster before, might have broken something. I carefully popped the gauges cover off and found one of the locking ears was broken and keeping it from working. Removed the ear, just got done putting it back together. I will hook it up to the vette in a bit and see if it works.
Old Oct 20, 2011 | 11:28 AM
tim1's Avatar
tim1
Well tearing into to find the issue made it work!!!! I have it installed and rest the CHANGE OIL light....... Just have to go out and install the shifter cover and bolt it in. I might even get to cruise to the beach if the weather here warms up a little.
Thanks for all the support and help.
Tim
Old Oct 20, 2011 | 12:24 PM
toptechx6's Avatar
toptechx6
Tim
Good job, glad you sorted it out.
