rewire 85' no electronics?
Old Oct 18, 2011 | 02:58 PM
david frederick's Avatar
david frederick
Default rewire 85' no electronics?
found 85' 8yrs. wet garage blown motor 4+3 mice+corrosion want to save this car. needs wiring. replaced motor with 87' carb. same trans. no electronics any help? thank you.
Old Oct 18, 2011 | 03:24 PM
dukeallen's Avatar
dukeallen
No electronics? Will it be a track car? Either way I hope your wallet is big.
Old Oct 18, 2011 | 03:35 PM
cv67's Avatar
cv67
St. Jude Donor '05
If it was worth saving it would have been done.
Parts car at best.
Old Oct 18, 2011 | 03:51 PM
david frederick
thought i was saving it ? 800. for car, 800. for motor, just needs wiring,gages tlc. tks.
Old Oct 18, 2011 | 03:54 PM
navy_vette's Avatar
navy_vette
Parts car at best.
With all that, I don't know if it will even be a parts car.
What electronics are missing? Just the ECM and such, or is the interior trashed?
If the interior is in good shape, I would say sell the Carb, head to a junkyard, and get an LT. There might be a wreck there that has a running motor. Just pull it out and fit it in. Make sure the wiring harness connections will fit the firewall plugs. It will still be a lot of work, but it'll probably be the best step 1 you can do to save her.
Old Oct 18, 2011 | 06:23 PM
david frederick
bought running motor needs wiring. want to keep this simple? old tech 60s like myself thank you. [ last corvette 1960 sold 1970 ]
Old Oct 18, 2011 | 06:51 PM
oldalaskaman's Avatar
oldalaskaman
call painless wiring, they have a web sight, you will not be sorry, wire it to a 74 or earlier, very little smog. BTW carb wiring can be very simple, if you just want to run it, then put in a main 12volt source and wire all the accessories to that. 74 was one of the early years for the hei distributer, an early one from a junk yard will run $40, keep that , its the best thing they did, cept for the small block.
Old Oct 19, 2011 | 04:51 PM
HlhnEast's Avatar
HlhnEast
Ol Dude on the right track. The only extra thing you will hafta worry about is the OD unit on the 4+3. Its electronically switched and also is tied to temp senders. I dont know exactly how this info is processed thru the ECM or other components. I suppose you could make it all manual control but without getting the FSM and sorting thru it I cant tell ya whats involved.
Old Oct 19, 2011 | 08:47 PM
oldalaskaman
he could make it a manual lockup/energize
Old Oct 19, 2011 | 09:25 PM
david frederick
thank you a vote of confidence.
Old Oct 19, 2011 | 09:27 PM
oldalaskaman
all it would take is a switch, the painless comes with 'complete' instructions, and they have a girl who works there who can walk you thru the head scratchin parts
Old Oct 19, 2011 | 11:10 PM
rodj's Avatar
rodj
ECM operates a relay that sends power to o/d solenoid.
All you need is a manual switch to operate said relay ( if still in place )
alternatively a fused switched supply direct to O/d solenoid
Old Oct 20, 2011 | 07:44 AM
HlhnEast's Avatar
HlhnEast
Thanks Rod.
To rewire 85' no electronics?
