Engine Pull Trans attached
Old Oct 25, 2011 | 02:32 PM
illenema's Avatar
illenema
Default Engine Pull Trans attached
Just a Note piece of cake to do with the happy hooker by TPIS.
Pulled engine and trans together Myself, No issues. Just pull the hood.
1995
***Yes I should have mentioned the trans NEEDED to be removed as well.
Old Oct 25, 2011 | 02:37 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
WOW! Its amazing how strong those 4-8mm bolts are.
Old Oct 25, 2011 | 02:42 PM
illenema's Avatar
illenema
Ya they go deep into the intake, that thing balanced the engine to perfection.
Old Oct 25, 2011 | 03:08 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Drop the trans, and you don't have to pull the hood.
Old Oct 25, 2011 | 04:24 PM
racerxz51's Avatar
racerxz51
Ididn't even drop the trans-put a stand and board to hold it in level in place, did the swap in 2 days from hood up/engine out to new engine in and running
Old Oct 25, 2011 | 05:16 PM
illenema's Avatar
illenema
Well if you ever need to remove the engine with the trans attached its pretty simple.
My trans needed to be removed as well. The engine thats going in has the trans/harness attached as well.
I was reading the horror archives about this and its pretty funny.
Old Oct 25, 2011 | 06:39 PM
oldalaskaman's Avatar
oldalaskaman
this is good info, thanks
Old Oct 25, 2011 | 06:57 PM
Aardwolf's Avatar
Aardwolf
I've seen pix of that and it always makes me a little nervous. I just use a bolt in the front of one head and the back of the opposite. Never needed to remove the hood.
To Engine Pull Trans attached
