Torq Thrust wheels/94 coupe
Old Nov 3, 2011 | 03:57 PM
Coondawg's Avatar
Coondawg
Originally Posted by Wathen1955
Question though for those that have the same tire on all 4 corners. What does that do to the handling of the car? Did you notice any difference? I'm asking because I don't understand why GM would put different tire sizes on the car to begin with unless it impacts handling of the car or maybe clearance.
For normal street driving, or daily driving to work in my case, the advantage of being able to rotate the tires to extend the life of the expensive tires of today, far offsets the potential loss of performance, assuming there is any. The amount of rubber on the ground is determined by the width, not rim size. I suppose a smaller sidewall translates to increased handling performance, but I'm never gonna notice with the kind of driving I do. For me, my car is a fun, good looking, cheap car that gets good gas mileage. Keeping it going and looking good for as long as possible are my main objectives. Being able to rotate tires helps me do this.
I think the staggered wheel and tire sizes are for stance and looks on moderate performance cars like my 86. It does look slick though.
Old Nov 4, 2011 | 03:50 PM
jumbo1290's Avatar
jumbo1290
Thanks for all the great info. I have decided to go with 17X9.5 all around and buy 285's for the front. Wheelsforless have the Torq Thrust 2.1's for $217 each, includes lugs,caps, chrome valve stems, and shipping!
2 options:
17X9.5 +46mm offset 7.06 inch backspace
17X9.5 +32mm offset 6.51 inch backspace
Ready to purchase, just don't want to make a mistake. tech had limited knowledge of late model C4's. Any recomendations or suggestions would be appreciated.
Old Nov 4, 2011 | 06:00 PM
IAFF alumni's Avatar
IAFF alumni
2 options:
http://www.joby.se/corvette/div/corvette_wheels/
From that link, it looks like...
1992 (base)
front & rear 17"x9.5" 56mm (7.4" backspacing)
Goodyear Eagle GSC, P275/40ZR-17
Old Nov 4, 2011 | 06:45 PM
jumbo1290's Avatar
jumbo1290
1992 (base)
I am aware of the factory wheel specs. Exact spec not available from Torq Thrust. Need to know which of the 2 options will work best with 285's .
Thanks,
Old Nov 4, 2011 | 06:56 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I used to run 17x10.5 Torq Thrust Ms on all four corners with 285/40/17 tires all around. I thought it looked awesome!
Old Nov 4, 2011 | 07:10 PM
Wathen1955's Avatar
Wathen1955
Does look nice with those wheels
I have a white 96. They have some that are black.
http://www.wheelsforless.com/america...rq_thrust.aspx
Wonder how they would look like on a white 96?
Old Nov 13, 2011 | 08:29 PM
sean257's Avatar
sean257
7th Gear
I was searching, and could not find any grey/anthracite wheels on a polo green, so I just pulled the trigger on these. TTII 9" front, 10.5" back. I have 255 front and 285 back.
Old Nov 13, 2011 | 08:38 PM
IAFF alumni
I like it.
Still cannot decide for myself... Torq-Thrust D's (with the grey centers), Torq-Thrust D's in chrome (like I have on my Cherokee), or Torq-Thrust II's.
Whatever I do, I'll retain the same size on all 4 corners like I have now.
